It is currently Mon Jan 22, 2018 8:05 am
Vehicle: hkbjk
Post Posted: Tue Nov 25, 2014 12:19 pm
Has anyone replaced the bearing in their tensioner pulley (AC and Power Steering 1999 Jimny)? Mine sounds like the bearing has issues and looking at the cost for a new pulley assembly $149! I wonder if anyone has pressed out the old bearing and pressed in a new one and if so do you remember the bearing you used?
Vehicle: 85 ' Drover
Post Posted: Tue Nov 25, 2014 2:49 pm
Its more than likely a standard bearing size, so if you measure it and ring up a bearing shop they should be able to supply you with something that will work.
Assuming it can be pressed out/in etc.
Vehicle: Suzuki Sierra Trayback
Post Posted: Tue Nov 25, 2014 8:18 pm
Done it a few times on Toyota's, bearing cost around $9. Was told that the actual V pulley does suffer from wear in a high klm engine.
Nick
Vehicle: hkbjk
Post Posted: Wed Nov 26, 2014 6:48 am
Ok thanks, I've taken then pulley off so will go to a bearing shop and see what I can find to suit
Vehicle: hkbjk
Post Posted: Thu Dec 04, 2014 5:34 am
Cost for the new bearing was $15 as opposed to $130 for a new pulley and bearing from online. Very simple to tap out the bearing and tap in the new one now is running like a champion again.
Vehicle: 2000 Jimny
Post Posted: Thu Dec 04, 2014 9:28 am
i changed the pulley in mine not too long ago, sourced an ebay unit for about $50 so you're in front of me at $15.
Vehicle: hkbjk
Post Posted: Thu Dec 04, 2014 9:49 am
That was for the whole pulley Im guessing? the $15 was for the bearing only as I did not need to replace the pulley
Vehicle: Suzuki Jimny 2010
Post Posted: Sat Dec 23, 2017 1:46 pm
Bearing is 80mm OD, 50mm ID and 16mm wide. Sealed both sides.
6010 - (2RS - I think 2RS means it has seals both sides). Ask the bearing shop for best one to suit application
2010 Jimny, M15A, 3" kit, 215/75R15, castor bushes (it's not enough!), rear shock btm mount brackets, panhard rod mounts, steering damper,
tx bash plate, radius arm bash plates, dual batts, headers, winch, side steps, rooftop tent, Joying HU, LED h/lts & d/lts,
Post Posted: Sat Dec 23, 2017 1:47 pm
That's for M13A engine
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC + 10 hours
