It is currently Tue Nov 24, 2026 12:53 pm
Vehicle: 1997 LWB V6 Vitara
Post Posted: Fri Nov 28, 2014 4:34 pm
So at the risk of repetition...
I've got a 97 lwb vit v6. It's bog stock (hence the name).
It needs new suspension so I want to know what others recommend. I want to get a kit rather than individual bits. I also want to lift it just a bit maybe a couple of inches.
Ta
Wayne
Post Posted: Thu Dec 04, 2014 7:43 pm
When I say suspension, I just mean springs and shocks. Plus a couple of bushes. I also want to put on bigger tyres, I was thinking 225/75/16.
If anyone wants to point me to any relevant threads that would be good too. I tried searching but didn't get far.
Thanks
Vehicle: Vitara 1994
Post Posted: Thu Dec 04, 2014 9:06 pm
If you want a basic bolt in kit with springs and shocks all the same brand with around 40mm lift just go OME. The three you want to fit are quite small so a 40mm OME kit will be perfect for what you want
Post Posted: Thu Dec 04, 2014 10:23 pm
hit up the business directory & shoot dank from kpd4x4 a PM regarding a dobinson kit, being an auszooker he'll do his best to look after you.
there are a heap of different spring rates to choose from depending on what you're planning on doing with it, there are only a handful of manufacturers who produce a longer travel strut for the from, OME, dobinson & ironman, either of the first 2 will get my money over the 3rd.
Users browsing this forum: Google [Bot] and 22 guests
