Joined: Fri Nov 26, 2010 10:57 pm Posts: 566 Location: Mid North Coast NSW
Posted: Sat Nov 29, 2014 1:20 am
What is evwryone using for an F10 alternator upgrade? I was going to run a falcon alt but the crank pukker can't be swswapped over as the vitara has 4 bolt holes for the crank, 1L has none....
You could swap the pully on the falcon one to a v belt and run that?? Mind you id try to avoid that kind of extra load on the f10 Can you take your alt off and wander into a wreckers? Just compare till you find something that works
Users browsing this forum: Google [Bot] and 144 guests
