It is currently Fri Nov 27, 2026 3:37 pm
Vehicle: suzuki Grand Vitara
Post Posted: Mon Dec 01, 2014 10:08 pm
Hey guys I recently bought a rear auto locker/LSD from 4xfourart (same as lockright) for my 03 GV and am yet to install it. Some guys I know mentioned that I should put one in the front at the same time or you can spin up the front and damage your gearbox? Apparently they have had to Fox this a couple of times (once on a tractor :oops:) is this a legitimate worry and does it happen often?
Post Posted: Mon Dec 01, 2014 10:22 pm
The guys you know don't know what they are talking about. :)
The GVs have a transfer case which splits drive 50/50 between the front and rear (when in 4WD).
They are right in the fact that without a locker, a wheel (the one with the least traction) will spin up as per any normal open diff. If this wheel was to gain traction suddenly it can (and will) cause driveline damage.
Most common damage from this is broken axles in the rear, broken CVs in the front, or a broken alloy front diff if you are unlucky enough to have one (yours should be steel however being an 03).
This has absolutely nothing to do with having a locker fitted to one end only. I dare say it would be less likely to happen as you are less likely to lose traction when lifting wheels etc.
I presume they are probably talking about transmission wind up, but lockers won't cause that (mismatched tyre sizes, mismatched diff ratios, driving in 4WD on high traction surfaces etc all will however).
TL:DR version - get a locker and have fun :cool:
Post Posted: Tue Dec 02, 2014 2:35 am
Ricey - I want to make sure you see this point, so I am going to underline it.
Post Posted: Wed Dec 03, 2014 4:37 pm
Awesome that's what I thought but just thought I should check, the guys do know about cars but probably not zooks and probably more in the v8 performance area Haha
Cheers for the info guys
Users browsing this forum: No registered users and 194 guests
