I have searched .. honest I have .. just been on Gumtree and found these .. will they fit (and pass a going over the pits for rego) a stock standard Serria LWB .. with a WT front clip
You will have contact between the tyre and the bumper outriggers, and the guards. It's not hard to overcome, but they don't clear a standard car.
No, 30's are 4" taller than the standard tyres, so no, they aren't legal. There is a proviso to this though. If you have a "commercial" model with 16" rims specifically mentioned on the tyre placard, you might be ok on a 30" tyre as the 6.50 16's fitted to these models are 28" tall.
If you're going over the pits keep it stock as a rock and fit your 30s later. The pits will pick on EVERYTHING, so don't give them ammunition.
When i went over the pits with mine they made me tighten a wheel bearing that had about 1mm of play in it on a 31" tyre. Sure, it needed snugging up, but they wrote that it needed immediate replacing with a new bearing. They're brutal. They also wrote me up to fix "Holes in the floor" - as i had my floor bungs out and sitting to the side of the holes under my floor mats. I offered to pop the bungs back in right infront of the guy and he refused to allow it, and wrote it up. I put them back in while he was pacing around the rest of the car. They also check any movement in your seat mechanisms and that all the adjustments work...
Users browsing this forum: Google [Bot] and 46 guests
