http://auszookers.com/forum/
Tyres / rims .. will these fit??
http://auszookers.com/forum/viewtopic.php?f=5&t=48651
Author:  prickle [ Wed Dec 03, 2014 10:24 am ]
Post subject:  Tyres / rims .. will these fit??
Collective grey matter.
I have searched .. honest I have :D .. just been on Gumtree and found these .. will they fit (and pass a going over the pits for rego) a stock standard Serria LWB .. with a WT front clip
30x9.50 maxxis buckshot mudders on 15x6, neg 5 offset sunraysia rims
Stuart
Author:  Gwagensteve [ Wed Dec 03, 2014 10:54 am ]
Post subject:  Re: Tyres / rims .. will these fit??
No and no, in short
You will have contact between the tyre and the bumper outriggers, and the guards. It's not hard to overcome, but they don't clear a standard car.
No, 30's are 4" taller than the standard tyres, so no, they aren't legal. There is a proviso to this though. If you have a "commercial" model with 16" rims specifically mentioned on the tyre placard, you might be ok on a 30" tyre as the 6.50 16's fitted to these models are 28" tall.
Author:  alien [ Wed Dec 03, 2014 12:38 pm ]
^^ What he said.
If you're going over the pits keep it stock as a rock and fit your 30s later. The pits will pick on EVERYTHING, so don't give them ammunition.
When i went over the pits with mine they made me tighten a wheel bearing that had about 1mm of play in it on a 31" tyre. Sure, it needed snugging up, but they wrote that it needed immediate replacing with a new bearing. They're brutal. They also wrote me up to fix "Holes in the floor" - as i had my floor bungs out and sitting to the side of the holes under my floor mats. I offered to pop the bungs back in right infront of the guy and he refused to allow it, and wrote it up. I put them back in while he was pacing around the rest of the car. They also check any movement in your seat mechanisms and that all the adjustments work...
Author:  prickle [ Wed Dec 03, 2014 4:34 pm ]
Hmmm dont really want to put new tyres on stock rims just for rego ... might have to borrow some for the day :)
