Joined: Fri Jun 21, 2013 1:27 pm Posts: 403 Location: Canberra, ACT
Vehicle: 1996 Leaf Sierra - Soft Top
Posted: Sun Dec 14, 2014 4:11 pm
So I have had the zook of the road for about a month now while I rebuilt the rear diff and fitted breathers. Finally it's all back together and runs smoothly but the reverse lights are constantly on when the car is on. The only thing that I did to wiring recently was move the trailer plug to a different spot... Could have stretched the wiring harnes but I'm not sure what I'd be looking for if that's the cause.
Any help towards this would be greatly appreciated! Thanks guys!
tested the reverse switch? theres a plug under the bonnet on the firewall leading to the gearbox, with a yellow and a red wire. on the bottom connector, use multimeter, should have continuity across the 2 pins in reverse, and nothing when not. thats how i checked mine when my reverse lights stopped...
