http://auszookers.com/forum/
Air Locker Leaking?
http://auszookers.com/forum/viewtopic.php?f=5&t=48990
Author:  klutched [ Tue Jan 13, 2015 1:18 pm ]
Post subject:  Air Locker Leaking?
Blew a CV on the weekend and the compressor started to go every 30 seconds or so. Assume the locker is leaking internally as I can't see/hear anything on the hose.
What's the best way to diagnose the problem?
Author:  tanshi [ Tue Jan 13, 2015 1:20 pm ]
Post subject:  Re: Air Locker Leaking?
open the fill plug. you will hear if the air is leaking internally or not.
from there its a pull the diff situation
Author:  christover1 [ Thu Jan 15, 2015 5:22 am ]
Soapy water sprayed on all joints to look for exterior leaks.
Internal, I personally would only fix next time diff is out..
unless it is not staying locked.
Author:  christover1 [ Thu Jan 15, 2015 5:24 am ]
My compressor (Chinasoong) died internally, causing a similar issue before it stopped altogether.
I have now fitted an ARB compressor.
Author:  henno [ Thu Jan 15, 2015 6:41 am ]
klutched has an ARB compressor, not the chinese copy.
