| hard to start, when gets to temp runs fine http://auszookers.com/forum/viewtopic.php?f=5&t=49621 |
| Author: | obsidian [ Sun Mar 22, 2015 10:01 pm ] |
| Post subject: | hard to start, when gets to temp runs fine |
Hello, First post on here so be gentle. I have come from a 1kz the Hilus to a 1.6a carb Vitara and wow am i impressed with the capabilities of these little trucks!! OK to the issue, it is extremely hard to start when i first start up, its cranks over perfectly starts up and sits on the 100rpm while it gets hot. Most of the time it will stall, so i start again and its take a bit longer to crank over and get started. Once i get it started i pump the gas a bit it will rev then almost cut out like no fuel is getting in to the system. after about 5mins of getting the temp up its ok to drive. Any help would be great? could it be a engine temp or oil temp sensor? Thanks in advance, nathan |
| Author: | fordem [ Sun Mar 22, 2015 11:53 pm ] |
| Post subject: | Re: hard to start, when gets to temp runs fine |
Nope, & nope, you have carb issues, probably choke related. |
| Author: | obsidian [ Tue Mar 24, 2015 11:05 am ] |
Thanks fordem, would you know what i would have to check for on the carb? or is it looking like a rebuild? |
