It is currently Mon Sep 21, 2026 7:55 am
Vehicle: Suzuki Sierra Lwb
Post Posted: Tue Apr 07, 2015 6:44 pm
Hey guys my problem has got worse now i can free rev the motor but as soon as i let the clutch out the engine stalls within about 5 seconds
Ive changed the fuel filter and air filter
The only code the computer is throwing is the O2 sensor code but does not explain this behavior
HELP its my only car atm
Brad
Post Posted: Tue Apr 07, 2015 6:46 pm
I should say that ive had no troubles in 4 odd months
Is it possible that bad fuel could be the cause ?
Post Posted: Thu Apr 09, 2015 7:42 pm
I got a a bit of time today and Ive found that there is no problems while it is cold but at running temp that's where the problem starts and its worse now as i can not free rev at all once it starts any change off idle it stalls
Any one have any ideas to help me ?????????????
Post Posted: Sun May 03, 2015 1:14 pm
Ok I've changed fuel filter air filter taken apart the throttle body and cleaned it all up and the problem is still there it is totally un drivable will still free rev but as soon as you go to take off any acceleration makes it want to stall
HELP PLEASE
Vehicle: 2000 Jimny
Post Posted: Sun May 03, 2015 8:29 pm
mine had a bad stutter on take off, is it fuel injected ? could it be the MAP sensor ? they're expensive, but if you have a spare you could swap it (or borrow from a friend).
Post Posted: Sun May 03, 2015 10:02 pm
How long have you been running with a bad O2 sensor? you may have stuffed the cat.
Post Posted: Mon May 04, 2015 8:18 am
I wouldn't have done 100km from when I've done the engine conversion
Post Posted: Tue May 05, 2015 1:38 pm
OK I solved the problem my self cleaned the EGR which was fine anyway and found a cracked vacuum line that goes to the charcoal canister. Problem fixed so far, I have to take it for a proper drive yet and see!
Users browsing this forum: Google [Bot] and 187 guests
