It is currently Wed Nov 18, 2026 1:38 am
Vehicle: Gran vit 2000
Post Posted: Mon Apr 27, 2015 1:26 am
Hey everyone
i have recently purchased a 2000 GV auto 4dr.
took the new zook out camping on the weekend went really well!! just needs some basic improvements.
one of my main killers was clearance since the car is standard.
I was thinking of a EFS shock/spring lift kit but still want a decide ride and it to handle light camping loads well.
I was also thinking a body lift aswell to allow for some slightly larger rubber to pick the clearance up that little bit more. :)
I'm really after some brand advice for suspension and opinions/facts on the body lift?
Also i am an ex jeep nut know heaps about TJ's not soo much about zooks but im sure heaps of it carry's over.
So any tips/advice/facts are welcome about this car?!? :)
Also has anyone managed to install a dual battery system under bonnet on a 4dr GV?
cheers Rhys
Post Posted: Mon Apr 27, 2015 3:24 am
How large do you want/need to go on the rubber?
The OE tire size is either 215/65R16 or 235/60R16 (essentially a 27 inch tire), I'm running 225/70R16 (roughly 28.4 inch) on the OE 16x7 Enkei alloys with OME springs, shocks & struts (about a 30mm lift) - no body lift, no rubbing, although it does come very close to the plastic inner guards in the front, I suspect a 225/75R16 will rub, that would be easily resolved.
Dual battery systems are possible - you may need to relocate the screen washer reservoir, later models have it in the guard, if your's doesn't, you can pick that up in a scrap yard and retro fit it to make room - as before, check the "rigs of Auszookers" section of the forums, see what the other GV owners have done.
Post Posted: Mon Apr 27, 2015 9:23 am
im thinking of heading towards a 28 or even better a 29 dont want to set the fuel economy to complete shit. Although it sems like it has the power to push them.
yeh id love OME but i just dont wanna spend that much $$ on a 30mm , if i was going to spend that much id think about the calmini 3" :P
The EFS kit comes in at 700-800 so its budget conscious and i have heard mostly good things about them.
Vehicle: 99 Grand Vitara
Post Posted: Mon Apr 27, 2015 10:29 am
Have a look at Jimnybits.co.uk, they have good coils. I run their 3" coils and love em. I would probably recommend the same for your build instead of going body lift path. That will see you running up to 31s with a bit of bashing guards etc. Anything over that I'd go bodylift.
Holden Commodore or Camira rear shocks and swap out the bush or just the eye to suit. I just drilled mine out.
Few brand on the market to choose from, if I was to get another set I'd personally go OME.
Definitely get a set of Camber Bolts if you don't have some already, and also some diff drop brackets. Both can be bought from Jimnybits
Here's a few pics
Soup Kitchen - Dobs 35mm lift kit, 225/75R16 KL71s.
Build Thread - viewtopic.php?f=4&t=44020
Brad's GV - XL7 40mm Lift (Lifted 90mm on GV) on 225/75R16 KM2s.
Build Thread - viewtopic.php?f=4&t=46777
Ninjamoses XL7 - Calmini 2.5" front springs and custom rears to suit, Dick Cepek DC2 16x8 -12 wrapped in 245/75R16 Goodyear Duratracs
Build Thread - viewtopic.php?f=4&t=27787
Ninjamoses's old GV - 2.5 Calmini Kit, 2" Body Lift, same wheels/tyres.
My GV - 3" Coils, 2" Body lift, 235/85R16 Mudhogs
Build Thread - viewtopic.php?f=4&t=32683
The IFS Toy COMP TRUCK - 35x12.5 on 16x7 -12 Sunraysias, 2" lift with a lot of cutting guards.
Build Thread - viewtopic.php?f=4&t=46549
That should give you a rough gauge of what your GV should look like with different size lifts etc.
http://www.strictly4x4.com.au
Post Posted: Mon Apr 27, 2015 1:58 pm
thank you klutched I was just looking at jimnybits 3" kit it looks impressive! what does it drive on road like?
also was the freight quite expensive?? cause those kits seem sooo cheap killing anything on the Aussie market!!
Post Posted: Mon Apr 27, 2015 4:31 pm
viewtopic.php?f=15&t=20219
Dank is the EFS man. Brillant bloke with great prices.
If you want a bullbar and winch I am just removing my JML winchbar with 9000lbs Bushranger winch (about $2500 cost) and looking to recover about $1500 for the two.
I am also removing the dual battery setup out of my 2000 GV so I have a 110amp/hr deep cycle batter and Optima Redtop Battery along with Redarc isolator maybe avalible. Dank supplied me with the batteries and eBay supplied the isolator.
If you want pics on the setup I can get it when the rain stops.
Where are you located as I'm in Cockatoo in Vic and freight might be expensive if your not semi local.
Dave
edit: I might also have the 5:12 diff centers and 225/75R16 Cooper ST Maxx tyres going as well (no rims) I will need to check if B4T has the original diff centers still in his shed and how much time I have to strip this shit off my GV before it sells. :lol:
Post Posted: Mon Apr 27, 2015 9:12 pm
bohuler unfortunately im way over in WA so freight would be super expensive i appreciate the offer though mate thanks!
A few pics of your dual batt setup would be great mate cheers.
Post Posted: Sat May 02, 2015 1:30 pm
It's nice and soft, especially compared to the dobinson kit installed in the soup kitchen. As for shipping, if you buy a few things it will be well worth it. I bought the coils and a snorkel at the same time think I paid $700 and something AUD.
Users browsing this forum: No registered users and 47 guests
