http://auszookers.com/forum/
SE416 Vitara Dual Battery
http://auszookers.com/forum/viewtopic.php?f=5&t=49944
Author:  SierraDan [ Mon Apr 27, 2015 7:36 pm ]
Post subject:  SE416 Vitara Dual Battery
I've spent all day looking for info/batteries for a 1.6L Vit.
AZ Search doesn't want me to use the word "Vitara".
I want it to go here and I want it to be 75-100Ah Deep Cycle
The smallest ones I can find are 10mm too long without changing the intake, 250mm long will work. Surely someone has put a decent battery in that spot or knows of a battery.
Thanks.
Author:  DarkHorse [ Sun May 10, 2015 11:06 pm ]
Post subject:  Re: SE416 Vitara Dual Battery
What's the problem?
Can't remember the specs, but it was the same physical size as the stock battery... with the isolator in front and the compressor next to it.
Author:  striker99 [ Mon May 11, 2015 7:20 am ]
I think from memory the century/Delco deep cycle 250mm long battery was about 60-70ah. optima d34 is only 55 ah 250mm long, but only 190mm to top of terminals, so good for a jimny...fast charging too apparently.
Author:  SierraDan [ Tue May 12, 2015 5:23 am ]
80Ah. 260x170x215. I need to change the intake and move the coil though. It's too tight a fit.
Author:  Gwagensteve [ Tue May 12, 2015 10:54 am ]
Needs more 33 10.5 :thefinger:
Author:  SierraDan [ Tue May 12, 2015 4:10 pm ]
Needs more body drop and cantilever
Author:  striker99 [ Tue May 12, 2015 7:15 pm ]
Century Deep Cycle, NS70T 75Ah - 260 (L) x 171 (W) x 202mm (H)
http://www.supercheapauto.com.au/online ... mendations
Might be an option?
Author:  SierraDan [ Tue May 12, 2015 8:56 pm ]
The picture I posted is of my car and the battery I bought.
$170, 80Ah. She'll be sweet.
Author:  toopy [ Wed May 13, 2015 1:53 pm ]
If thats an AGM it wont like being so close to the exhaust manifold
Author:  SierraDan [ Wed May 13, 2015 6:14 pm ]
It'll be protected.
Author:  Pico42 [ Thu May 14, 2015 7:02 pm ]
620CCA, no idea of amp-hours.
Author:  SierraDan [ Thu May 14, 2015 7:41 pm ]
That's the other intake setup and stock position for that model, right?
Author:  Gwagensteve [ Fri May 15, 2015 1:24 pm ]
Yeah-that's the later model injection.
