It is currently Wed Nov 18, 2026 2:57 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
Post Posted: Thu Apr 30, 2015 12:56 am
Hey all,
Need help from the Suzuki gods...
To get my car engineered (yes, I'm still trying... can't let go...) I need to try to establish that the stock SV620 running gear will be fine with the XL7 rims (offset being the main concern.) A convenient way to establish this would be to compare the dimensions of the wheel bearings, as this also indicates both the axle and diff tube or spindle sizes.
So, what I would love to find out is the ID, OD, and any other specs, front and rear, of the following: (the list is extensive because there seem to be a bunch of differing and contradictory spec sheets available)
1993 1.6 LWB SE416 Vitara
1997 2.0 LWB SV620 Vitara
1999 2.5 LWB SQ625 Grand Vitara
1999 2.7 LWB SQ627 Grand Vitara XL7
I have weaves on the hunt, but if anyone else can jump in that would be amazing.
Post Posted: Thu Apr 30, 2015 2:08 am
So far Googling has turned up an OEM Suzuki Sidekicks and Geo Trackers 1989 to 2000
Suzuki P/N: 09269-41001, TIMKEN P/N: 517009, AC-Delco P/N: FW176
Height 1 : 40 mm
Height 2 : 35 mm
Outer Diameter : 68 mm
Inner Diameter : 41 mm
BUT...
Did the bearing change when Vits went to 26 spline axles?
Changed again for ABS/unified hubs on GV/XL7? (Suzuki P/N: 43401-65D00???)
Post Posted: Thu Apr 30, 2015 2:27 am
Timken catalogue (US models):
93 Sidekick
F - 517009
R - 511004
97 Sidekick
F - 517009
R - 511004
99 GV
F - 517009
R - 511024
02 XL7 (earliest available)
F - 513193 (Hub assembly)
R - 511030
Can anyone turn these into dimensions? Change in part numbers for XL7 isn't promising...
Vehicle: SWB Vit
Post Posted: Thu Apr 30, 2015 8:20 am
This site may pull up some answers
http://www.alliedbearings.com.au/datasheets/suzuki/seals-vehicles
Post Posted: Thu Apr 30, 2015 10:04 am
Got a reply from Greg at 4WD Products:
"The wheel bearing for the first three models is all the same being 41X68X40/35 (Suzuki OEM P/No. 09267-41001). I don't have the specific details on the XL7 wheel bearing as the wheel bearing is part of the hub (Suzuki OEM P/No. 43401-65D10).
Post Posted: Thu Apr 30, 2015 4:04 pm
93 Sidekick
F - 517009
Same as below
R - 511004
Same as below
97 Sidekick
F - 517009
Same as below
R - 511004
Bore Diameter (in):1.378 in.
Outer Diameter (in):3.149 in.
Width (in):1.023 in.
99 GV
F - 517009
Bore Diameter (in):1.614 in.
Outer Diameter (in):2.677 in.
Width (in):1.574 in.
R - 511024
Bore Diameter (in):1.575 in.
Outer Diameter (in):3.150 in.
Width (in):0.906 in.
R - 511030
Bore Diameter (in):1.574 in
Outer Diameter (in):2.913 in.
Width (in):1.607 in.
Can't do the hub assembly sorry.
Edit: Actually looked at the figures, it looks like you are out of luck with this avenue. That width difference is going to have a huge difference on torsional ability.
Post Posted: Thu Apr 30, 2015 4:07 pm
Thanks ozzy,
Allied lists a single bearing kit for all 88-99 Vitara models without ABS:
Fr: 4037
Rr: 4051
GV 98-00
Fr: 4037
Rr: 4435
...and the same for the XL7 despite the unitised front hub...?
Post Posted: Thu Apr 30, 2015 4:18 pm
Thanks Zook_Fan,
So all the Vitaras, 1.6 and 2L, front and rear used the same bearing??? Part numbers just different seals in the kits?
Then for the GV a bigger ID at both ends, so thicker axles... but a significantly smaller OD on the front countered by a much greater width. Rear pretty much the same...
Then the XL7 gets a much wider rear bearing but otherwise much the same.
Can I ask where you got those numbers from? Have to sort out the incongruity between sources now.
For the record if I can compare to an early GV that will be OK, I found a set of 16" alloys from a 98 V6 that are the same offset as my XL7 rims.
...there's no easy way to run GV hubs on an SV is there?
Post Posted: Thu Apr 30, 2015 8:13 pm
PM weaves? I have him on facey... not sure if he's still in the bearing game?
Post Posted: Thu Apr 30, 2015 11:17 pm
Have done, he's on it. Been some help with part numbers but got to go digging for dimensions.
Post Posted: Fri May 01, 2015 8:15 am
They were out of a giant Timken catalogue. Condition monitoring contractor brought it in yesterday but realised it was only imperial. Here is a link to a Timken metric/imperial catalogue: http://www.timken.com/en-us/products/Do ... _Guide.pdf
I'm only going by the part numbers you gave me, I didn't check your information to see if they were the same or not. Can't imagine the GV front hubs would be hard to install on the vit but I haven't done it so can't give guidance there.
Post Posted: Fri May 01, 2015 8:42 am
gv hubs and spindles should fit right on a vit. but you would have to get the spindles too as they don't fit on vit ones.
Post Posted: Sun May 03, 2015 3:29 pm
Thanks guys...
ZF - from the link you posted:
Vit - 517009 - ID = 41, OD = 68, W = 35-40
- 511004 - ID = 35 OD = 80, W = 26
GV - 511024 No listing, but a Google gives the same dimensions, translated to Bore = 40mm OD = 80mm, W = 23mm
XL7 - 513193 - No listing
- 511030 - No listng, Google again agrees - Bore = 40mm OD = 74mm, W = 41mm
Tanshi - so GV spindles and hubs will bolt onto a Vit knuckle, giving me GV bearings... will I need GV CVs too, or is there a shim or something for that extra 1mm bore size?
Post Posted: Sun May 03, 2015 8:47 pm
So based on all of that the engineer is happy with the front end, but not so much the back.
Can anyone tell me how the thicker rear axles on the GV (40mm) compare to the SV (35mm)? Is there any chance they taper down to the same size and spline count at the diff end? Are they the same arrangement at the wheel end? Are they even the same length???
Brakes have also been passed, so it's actually tantalisingly close to happening now...
Post Posted: Mon May 04, 2015 5:04 am
All 26 spline suzuki axles would be the same size at the spline to fit in the side gears
Post Posted: Mon May 04, 2015 5:09 am
Try and find the rated axle load capacity of the gv sv and cj7 front. Might be able to go to full floater at last resort. I have a gv axles here if u need measurments.
Post Posted: Mon May 04, 2015 5:22 am
I found 900kg front and 1060kg rear for a gv in the states.
Post Posted: Mon May 04, 2015 9:24 pm
Thanks Luke... any info on Sidekick/Trakker to compare to?
Post Posted: Mon May 04, 2015 9:47 pm
Some more info from here:
http://www.adelaidestreetcruisers.com.a ... eights.pdf (SA Govt)
These are Wheel Track, so stock offset rims and tyres:
Vit
Front 1395
Rear 1400
V6 Vit
Front 1465
Rear 1450
GV 98-01
Front 1500
Rear 1500
GV SWB 98-01
Front 1460
Rear 1460
Post Posted: Tue May 05, 2015 5:46 am
Found these on zukiworld might help . They were us ones but should be close
Gross axle weights
Sv front 800kg
Sv rear 960kg
Gv front 900kg
Gv rear 1060 kg
Xl7 front 1000kg
Xl7 rear 1300kg
Post Posted: Tue May 05, 2015 6:12 pm
Cheers Luke. The more data I can throw at the engineer the better!
Post Posted: Tue May 05, 2015 6:46 pm
If u use xl7 front hubs in a full floater u will be right.
Swb gv axle dimensions
Rhs bearing spacer to end of spline 656mm
Drum mating surface to spline 756
Lhs 610 and 710
Post Posted: Fri May 08, 2015 10:26 pm
Luke you're all sorts of awesome.
Do you know if the stud pattern for the drums is the same as the SV? And the backing plate to housing bolts match the SV?
From the data above the SWB GV is all of 10mm wider than the SV in the rear... which would all be on account of the change from P25 to P10 offset... what are the chances these would be a straight swap???
Post Posted: Sat May 09, 2015 5:00 am
Isnt the bearings bigger on the gv
Are u in Sydney. Club meeting is Wednesday if u want to try them
Post Posted: Sat May 09, 2015 5:02 am
U might be able to drop the entire gv housing under if the arm mounts and coils line up
Post Posted: Sat May 09, 2015 11:34 am
Bearing OD apparently is the same.
I could probably make it Wednesday... but I won't have access to my car.
What are the chances of everything lining up? Will the disk kit bolt up?
Post Posted: Sat May 09, 2015 1:24 pm
I will get a heap of measurments of the housing when i get home as well as the lwb housing
Post Posted: Sun May 10, 2015 12:25 am
If you could be bothered chucking one of the GV axles into the SV diff that would be awesome - that's the least painful potential solution that I can think of...
Otherwise thankyou so much!
Post Posted: Sun May 10, 2015 6:49 am
I only have a swb gv diff in pieces is your sv diff together .
The bearing has a spacer on the center side of it.Check with greg the sv one might be 6mm shorter. It makes sense for suzuki to use the same housing when they went to the new wide chassis
Post Posted: Sun May 10, 2015 8:18 am
Swb gv Outside of housing to outside outside of housing is 1370Image
Center of arm mounts 1115 Image
