Page 1 of 1
[ 5 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
mrw82
Joined: Tue Jul 03, 2007 11:30 pm Posts: 1350 Location: stuck in a hole. not off road, just deception bay.
 Posted: Tue May 05, 2015 7:37 pm |
Might be a silly question, but can a 1.3 clutch/flywheel be used in a vitara?
I know it can bolt up to the engine (as per a g16 into sierra conversion, to run the Sierra box), but unsure if the vitara gearbox would mate up to the G13 clutch. Can anyone confirm or deny?
Reason I ask is I might need to replace the clutch in a vitara, but it'll only have a short life 6-12 months max, before getting dropped into a sierra. Don't want to have to buy 2 clutches if one will do the job.
Bulldog 61
Vehicle: SJ70 Tintop, SJ51T, 97 Coily
 Posted: Wed May 06, 2015 4:44 pm |
mrw82 wrote: Might be a silly question, but can a 1.3 clutch/flywheel be used in a vitara?
Reason I ask is I might need to replace the clutch in a vitara, but it'll only have a short life 6-12 months max, before getting dropped into a sierra. Don't want to have to buy 2 clutches if one will do the job. Mate get onto Bretski on here, Im buying a 1.6 off him to do the swap and I don't need the clutch pressure plate or flywheel, if its ok might save you buying a new one.
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Wed May 06, 2015 4:46 pm |
Reason I ask is I might need to replace the clutch in a vitara, but it'll only have a short life 6-12 months max, before getting dropped into a sierra. Don't want to have to buy 2 clutches if one will do the job. ask Tim, there was a brand new clutch on the engine I just sold him that he wont be using
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Wed May 06, 2015 6:15 pm |
Pretty sure input shafts are different. Exedy website should confirm that
mrw82
 Posted: Wed May 06, 2015 8:08 pm |
tanshi wrote: mrw82 wrote: Might be a silly question, but can a 1.3 clutch/flywheel be used in a vitara?
Reason I ask is I might need to replace the clutch in a vitara, but it'll only have a short life 6-12 months max, before getting dropped into a sierra. Don't want to have to buy 2 clutches if one will do the job. ask Tim, there was a brand new clutch on the engine I just sold him that he wont be using Already onto it. Thanks Darren. Keeps the vitara alive for a bit longer while it's needed. Now the fun job of installing it...
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: Google [Bot] and 66 guests
