| mg410 harness mounts http://auszookers.com/forum/viewtopic.php?f=5&t=50023 |
| Author: | jonno_racing [ Tue May 05, 2015 9:23 pm ] |
| Post subject: | mg410 harness mounts |
Hey guys. I'm looking for a way to mount 4pt harnesses in my maruti without an internal cage. The sides are reasonably easy, I can pick up off factory bolts and use lifting bolts (cams is ok with this) However the rears are a bit more tricky? Any ideas? I'd like to keep as much useable space behind the seats as I can. |
| Author: | tanshi [ Wed May 06, 2015 8:18 am ] |
| Post subject: | Re: mg410 harness mounts |
bolt in a harness bar mounted to the stock seat belt bolts on either side. ?? does it really need to be cams compliant? |
| Author: | jonno_racing [ Wed May 06, 2015 3:20 pm ] |
That's fine for the lowers. The straps from over the shoulders is the issue. Nope to cams, just using it as a guide. |
| Author: | tanshi [ Wed May 06, 2015 3:47 pm ] |
nah I mean for the uppers. ill try and model what I mean |
| Author: | jonno_racing [ Wed May 06, 2015 4:02 pm ] |
Yeah that looks about what I'm thinking. Push that hard back against the cab wall.. Could just weld it in permiantly |
