http://auszookers.com/forum/
Steering shaft spacer for body lift.
http://auszookers.com/forum/viewtopic.php?f=5&t=50151
Author:  wdoyle2410 [ Thu May 21, 2015 7:42 pm ]
Post subject:  Steering shaft spacer for body lift.
For those of you who have put a 2" body lift in, is a steering shaft spacer needed? And if so where would I find one for my sv420 swb bit?
Author:  Gwagensteve [ Thu May 21, 2015 7:44 pm ]
Post subject:  Re: Steering shaft spacer for body lift.
I've body lifted a few Vitaras and a heap of sierras. Never needed one.
Author:  vet 180 [ Thu May 21, 2015 8:50 pm ]
Slightly OT but you don't seem like the type to body lift. Low and flat on big rubber seems more your theme.....
Author:  MrRocky [ Thu May 21, 2015 11:26 pm ]
Body lift clears tyres and keeps all the weight of chassis alot lower than a susp lift. But bodys can walk on the mounts in extreme cases
Can u not just double up on the steering biscuit
Author:  Gwagensteve [ Fri May 22, 2015 7:20 am ]
A BL is just a tool to fit bigger tyres. For example, it's quite difficult (but not impossible) to fit 35's on a low sierra without a body lift. For cars with tight guards that are difficult to cut, like a LWB Vitara, a BL can be very useful.
Mr Rocky's comments are spot on.
Author:  jdk81 [ Fri May 22, 2015 9:27 am ]
Just extend the steering shaft?
Take it out, and tap it to lengthen it a little.
They are collapsible for crash purposes, there is enough length to safely extend it a tiny bit for a BL.
Author:  wdoyle2410 [ Fri May 22, 2015 4:34 pm ]
Cheers for the replies, hopefully all goes well without one.
Author:  Pico42 [ Fri May 22, 2015 9:52 pm ]
I didn't really need one for 2" body lift, there was enough in the spline. I fitted some from bits4vits when we went to the 3" body lift.
