It is currently Sun Nov 15, 2026 10:33 am
Post Posted: Thu Jul 23, 2015 7:48 pm
Hey guys,
Just wondering what would cause a H25A grand vitara clutch hard to push?
Clutch seems ok, gears are pretty good, reverse will crunch If i dont run through 1st and 2nd first.
But the pedal is rediculously hard to press. Im doing a lot of traffic driving now so I have to fix it.
Thanks
Vehicle: zook
Post Posted: Thu Jul 23, 2015 8:33 pm
I had the same complaint with mine (although j20a) until i changed the clutch two weeks ago.
I found the fulcrum pin was punching through the fork.
The clutch had signs of wearing thin for a while, like you describe trouble selecting reverse, and slow to shift in 1st and 2nd as the plate was not fully disengaging.
The one I replaced was an OEM Aisin, down to the rivets, probably the original clutch ,180,000km. I replaced it with an OEM style Exedy clutch, replaced the fork ($45 from Suzuki) and spigot bearing.
Now I have a nice light clutch pedal and my left leg thanks me for it.
Vehicle: zook
Post Posted: Thu Jul 23, 2015 8:36 pm
The other thing I noticed was the old thrust bearing was sliding quite stiff on the input shaft shroud whereas the new bearing had good clearance.
Post Posted: Fri Jul 24, 2015 5:23 am
Dammit. Not the news I was hoping for
Post Posted: Sat Sep 19, 2015 6:12 pm
Can anyone advise if dirty clutch fluid could make the pedal hard or is it most fefinately an internal issue?
Post Posted: Sat Sep 19, 2015 10:42 pm
I'd say it's not impossible, but I don't think it's very likely - my guess is it's either the clutch fork (I have one that looks just like it, the crack might be a wee bit smaller) or the release bearing.
Users browsing this forum: No registered users and 78 guests
