It is currently Sun Nov 15, 2026 10:14 am
Vehicle: Not a zook yet
Post Posted: Sun Sep 13, 2015 6:15 pm
Afternoon, done a search on here but couldn't find the info I was after. where are people getting there suspension parts from? ive done a search on the net but I'm not all that good on using the net... more interested in diff drop brackets and rear diff drop brackets then springs and shocks.
Vehicle: SJ80, SE416
Post Posted: Sun Sep 13, 2015 11:03 pm
Bits4Vits
Post Posted: Mon Sep 14, 2015 6:27 am
Reubs wrote:
Bits4Vits
Me too.
Post Posted: Mon Sep 14, 2015 11:56 am
thanks guys
Post Posted: Mon Sep 14, 2015 12:06 pm
I got on to another bloke over the UK. I ordered a couple things but he didn't make diff drop brackets for the v6. thanks the help
Vehicle: Suzuki Vitara 1992
Post Posted: Thu Sep 17, 2015 1:13 am
i got 2" lift kit from jimnybits.co.uk got it within 4 days (if i remember correct).
Post Posted: Thu Sep 17, 2015 2:55 am
Rear diff drop brackets ?!?
Post Posted: Thu Sep 17, 2015 6:29 am
Meant spacer that sits bolts to top of the diff.
Post Posted: Thu Sep 17, 2015 10:55 am
I wouldn't fit a diff spacer unless you had proven the shock lengths you are running make it necessary. They raise roll centre and reduce antisquat, neither of which is especially desirable.
Post Posted: Sun Sep 20, 2015 7:19 am
As shocks are 3 inches longer then standard I will be fitting one. But in saying that with the new shock brackets I may not need to fit it.
Once I have the parts here I will be able to work out if needed or not, seeing its all coming from the UK it is easier to order it all now,
then if it is not needed it can be sold on.
Users browsing this forum: Google Adsense [Bot] and 62 guests
