Joined: Fri Oct 22, 2010 2:18 am Posts: 14 Location: Yeppoon
Posted: Tue Sep 15, 2015 5:49 pm
Hey all was wondering if someone can get the thickness to the 0.1mm of the isolator (without gaskets) that goes in between the head and the mechanical fuel pump please. I need to make one as I'm getting the run around by a certain business and need to get this conversion going.
Posted: Fri Sep 18, 2015 7:11 am
From Suzishop Dave "6mm" - thanks mate.
I had to make one out of nylon to at least get the car running but seemed to work well. Car starts and runs, now just ironing out the bugs. Might write up a bit of a tech article on the G16 conversion as this engine had the G16 head as well and a lot of parts needed to be modified to suit the G13 ancillaries.
Users browsing this forum: No registered users and 57 guests
