It is currently Sun Nov 15, 2026 4:00 am
Vehicle: Grand Vitara 1998
Post Posted: Mon Sep 21, 2015 7:22 pm
I have a set of 50mm raised Jimnybits coils for my LWB GV.
I'm wondering if I should run the coil correction spacer in the front or the 15mm spacers on top of the coil.
Will each of these methods lift the front roughly the same?
Are coil correction spacers necessary on a 50mm coil?
Vehicle: 2004 GV sport v6
Post Posted: Thu Sep 24, 2015 8:45 pm
No no and no don't run the correction spacers they are crap, to be honest all spacers are crap
Post Posted: Fri Sep 25, 2015 8:52 am
I've got 3" coils in the back but only have 2" coils for the front.
I need something to get my up to level.
Vehicle: Which one?
Post Posted: Fri Sep 25, 2015 1:25 pm
Replace the rear coils.
Post Posted: Fri Sep 25, 2015 1:32 pm
would like to keep it 3" all the way around.
Think i may go down the new LCA route with 3" coils.
Vehicle: Which one?
Post Posted: Fri Sep 25, 2015 2:23 pm
Why do you need 3" of lift? I would argue that it's going to be far easier and cheaper to lower the rear by an inch than it is raising the front by an inch.
Unless you want to do it dodgy, of course.
Post Posted: Sat Sep 26, 2015 4:49 am
In addition to the caster/camber issues that the new LCAs will solve, you also need some sort of strut extender/spacer to avoid "topping out" the struts, diff drop brackets to reduce the angle on the CVs at full droop, and probably the right axle support bush for the front diff.
Like Henno says - it's a lot easier to lower the back an inch than it is to raise the front that extra inch.
Users browsing this forum: No registered users and 88 guests
