| Author |
Message |
suzukikid
Joined: Sun Jan 14, 2007 10:30 pm Posts: 2803 Location: Melton Victoria!
 Posted: Sat Nov 14, 2015 4:41 pm |
Thinking of painting my Zook in kill rust Matt black has anyone painted their car with kill rust?
craigtempo
Vehicle: suzuki sierra lwb
 Posted: Sat Nov 14, 2015 5:50 pm |
Have a look at hamerite paint as well
suzukikid
 Posted: Sat Nov 14, 2015 9:58 pm |
As in hammer tone? Or is that a brand?
missmyljdaze
Joined: Tue Jul 05, 2011 7:16 am Posts: 2323 Location: perth
 Posted: Sat Nov 14, 2015 10:54 pm |
More or less the same stuff, just different manufacturers.
Only painting in killrust wont stop rust - a bit more prep. is needed.
A good spray of R10, [converter] wait a day or so for it to do it's stuff, Followed by a good shot of penetrol [sealer] and letting it creep into the seams etc will be a huge help. The handy part about using both these on zooks, is that you can do it all yourself without making the car un-drivable while doing your prep.
This will for all intents halt the spread of the rust you have, and prevent any new rust starting.
Then you can head to Bunnings and pick up the matt black killrust or hammerite or hammertone , a roller and go do your painting! -------------------------------------------
Then again.........you could always be different and try Shep's awesome painting tips + glow-in-the-dark-paint
stephen
suzukikid
 Posted: Sun Nov 15, 2015 9:44 am |
I forgot about the glow in the dark! Hahaha
It's all stripped mate ready for a body swap! So doesn't have to be drivable! What would happen if I didn't do that prep? Haha
It's already coated in protec green witch I hate! Doors and bonnet are stock paint so I will have to sand them ect
missmyljdaze
 Posted: Sun Nov 15, 2015 4:50 pm |
since the zook is stripped, you can get serious and use the R10 and Penetrol to get inside all the hidden seams and rust traps.
inside the doors and pillars, inside the windscreen frame and similar areas.
easy to do, and cheap insurance!
stephen
suzukikid
 Posted: Mon Nov 16, 2015 9:36 am |
Is it worth doing that if the body has no rust?
I was hoping to just sand and spray! Haha
missmyljdaze
 Posted: Tue Nov 17, 2015 1:02 am |
suzukikid wrote: Is it worth doing that if the body has no rust?
I was hoping to just sand and spray! Haha all depends on how long you intend to keep your zook, if your zook will ever go swimming or be exposed to salt. It isn't so much the outside of the car you need to worry about - its the rust that starts inside the hidden bits. stephen
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5944 Location: Northcliffe, W.A.
 Posted: Tue Nov 17, 2015 1:30 pm |
This^.
My Sierra was repainted but that didn't save it from the seam rust which has ultimately put it off the road for good.
Well worth doing all the seams properly IMO.
suzukikid
 Posted: Tue Nov 17, 2015 3:22 pm |
Ok may as well do it properly! Haha now where is the best place this stuff?
suzukikid
 Posted: Tue Nov 17, 2015 3:59 pm |
Just doing some research on this products! The r10 is sprayed on first? Then the other one is mixed into the paint?
suzukikid
 Posted: Tue Nov 17, 2015 7:39 pm |
Done more research again!
When I said it was stripped I didn't mean back to bare metal.... So I can't use the r10?
missmyljdaze
 Posted: Wed Nov 18, 2015 12:14 am |
R10 will work on rust - as long as it can get to it.
Just brush, scrape or chip off the loose bits of rust - the R10 will convert the rest into nice stable paint friendly surface.
Dampen the area to be treated - I use an old windex spray bottle [R10 works better on a damp surface, as the stuff can soak into the rust a lot easier]
Once the R10 has done it's stuff [around 24 hours] wipe off any loose residue if you can, then spray, squirt or brush raw Penetrol onto / into any areas you can reach.
The Penetrol will creep along seams and seal any bare metal, treated rust and even untreated rust from air. [oxygen is needed to form rust]
You can also add Penetrol to paint - makes it cover better, but check with both the paint and penetrol manufacturers for better advice than mine!
Penetrol is available in spray cans [pricey] or in tins [better value] but a spray can might be easier for doing inside doors and behind dashboard type of areas.
stephen
suzukikid
 Posted: Fri Nov 20, 2015 6:01 pm |
Righto I'll chat to the people at the paint shop!
Thanks for all your help mate
