It is currently Wed Oct 14, 2026 12:02 am
Vehicle: Suzuki Vitara SV420
Post Posted: Mon Nov 16, 2015 8:04 pm
Hi all,
Took my '92 SWB out for it's first proper test and i was pleasantly surprised at the results !!!
The only issue i found was that the body cut into the back tyres at full flex ? I have 31" muddies, 2 ' suspesion life and 2" body lift on. The previous owner said that the suspension lift was 2", but after checking the serial numbers on the springs and shocks it seems like the springs are just 30mm and the Ultima shocks looks like a straight replacement for the standard ones.
Can anybody give some advice on a cost effective yet simple solution to rectify this problem please ?
Bush Pig
Post Posted: Mon Nov 16, 2015 10:16 pm
Bumpstop spacers. space the bumpstop the appropriate amount so your tyres will clear.
If you have a search throughout the forum you will find the information you seek.
Post Posted: Tue Nov 17, 2015 8:30 am
Alternatively, if you dont care about the body, hammer back the seam on the inside of the wheel arch that is cutting into the tyres.
Post Posted: Tue Nov 17, 2015 8:38 am
Even if you do care about the body the above suggestion is still a must , just do it carefully and gradually and there shouldn't be to much of a problem .
Post Posted: Tue Nov 17, 2015 10:46 am
I have no issues hammering the seam, but i have some rubber flairs that i have pop riveted to the seam.
Can i just get some extension brackets for the shocks ?
Post Posted: Tue Nov 17, 2015 10:58 am
Get more correct offset
I run 32"s with minimal guard massaging
Post Posted: Tue Nov 17, 2015 11:21 am
Where abouts is the body hitting
Back of door =longer arms or cutting will fix
Bumper =only cutting will fix
Top of guard. 10p rims will clear the guard if the lip is folded up back onto it self. U might need to hit the inner guard in a bit of it rubs. I used a slege hammer and a 2x4 to work it in a bit on my lwb.
Shocks or springs have no affect on tire clearence.
If your tires hang way out the guards and hit still i will need bumpstop spacer or cut the guard and weld a strip back in to fill the gap
Post Posted: Tue Nov 17, 2015 11:40 am
I bought the vehicle with brand new rims and tyres so no point in replacing them now.
It is hitting the top of the guard at full flex. Will bump stops limit my travel ?
Looks like i will have to modify it some how and just make a plan to put the rubber flares back on then.
Let the fun and games begin !
Post Posted: Wed Nov 18, 2015 7:02 pm
I used the rubber flairs that screw from the side not to the under side of the lip
Bump stop spacer will loss some travel but will let u run longer shocks or shock relocation bracket if your coils are not to short
U can cut the guards out if u want
Post Posted: Wed Nov 18, 2015 8:31 pm
That sounds like a good idea, thanx.
Where can i buy the flares that screw from the side ?
Post Posted: Thu Nov 19, 2015 6:57 pm
I got mine off ebay. It was a few years ago now.
Post Posted: Thu Nov 19, 2015 7:14 pm
I also found some at Clark Rubber today, but they are between $27 - $37/m. Will check out Ebay as well
Users browsing this forum: Google [Bot] and 264 guests
