It is currently Fri Sep 25, 2026 5:26 pm
Post Posted: Wed Jun 10, 2009 9:30 pm
i have recently done a spoa onversion and in second gear at about 2500-3000 rpm i get a vibration/shudder doesnt happen in other gears just at those revs in 2nd gear, any idea wat it is
Post Posted: Wed Jun 10, 2009 9:33 pm
how much overall lift do you have?
otherwise check your transfer mounts
Post Posted: Wed Jun 10, 2009 9:34 pm
show us pics...........
Post Posted: Wed Jun 10, 2009 9:48 pm
answer PM's :lol:
Post Posted: Wed Jun 10, 2009 9:49 pm
standard springs and body lift. front bars modded to suit body lift.
Post Posted: Wed Jun 10, 2009 9:57 pm
Had a similar problem when I put a 6" lift kit in my GQ. Check your uni's and uni angles
Post Posted: Wed Jun 10, 2009 10:34 pm
Post Posted: Wed Jun 10, 2009 10:35 pm
If you accidentally dropped the drive shafts out of the splines and then put them back in with the uni's not aligned you will get that problem. It will go away or be less noticeable in higher gears.
Second issue could be the alignment pic below gives you the idea, the uni's should be parallel with each other top and bottom
i had the uni's the wrong way to start both facing the same way that helped a bit fixing that but still there.
Post Posted: Wed Jun 10, 2009 10:43 pm
by the look of your front springs, you going to get lots of axle wrap.
Post Posted: Wed Jun 10, 2009 11:18 pm
oh really whys that?
Post Posted: Thu Jun 11, 2009 12:33 am
put those rock lights to some use...pics of rear end.
Post Posted: Thu Jun 11, 2009 12:36 am
They look like standard springs to me..
Post Posted: Thu Jun 11, 2009 1:03 am
my spoa does the same thing. shudder/vibs in 2nd. does your do it a tiny bit in 3rd?
i thing i did was rebuild the tcase. that did help but its still there and to me its now a 'zook thing' however if you do fix it please let me know
Post Posted: Thu Jun 11, 2009 1:07 am
i have read that you use the front dc tailshaft from a hilux to fix the vibe.
i'd be checking the unis or how much of your slip joint is out
Post Posted: Thu Jun 11, 2009 1:45 am
from what i have read also about dc shaft is there put more strain on the output of the tcase being a heavy thing.
Post Posted: Thu Jun 11, 2009 2:12 am
doesnt really shudder in 3rd just 2nd.
slip joint is out about an 1' front shaft doesnt even reach
Post Posted: Thu Jun 11, 2009 2:15 am
loading up more pics now
Post Posted: Thu Jun 11, 2009 2:31 am
Vehicle: WR250F/Jeep XJ
Post Posted: Thu Jun 11, 2009 2:51 am
There is something weird going on with your rear end. The pinion angle in relation to your spring pads looks very strange. Did you make sure you welded the pads on in the right location? The pinion should be closer to parallel to the ground rather than pointing at the output shaft of the tranny. maybe fix with castor wedges.
Post Posted: Thu Jun 11, 2009 3:06 am
i didnt weld the perches on they were already done. they were out of a mates car.
Post Posted: Thu Jun 11, 2009 3:36 am
for starters you will need some shorter leaves in there or your pack won't last long, and secondly the pinion angle is not right. the new perch must be paralell to the old one.
Post Posted: Thu Jun 11, 2009 3:43 am
im pretty sure it is parrallel to the old one. oh k so what leafs do i need to put in?
Post Posted: Thu Jun 11, 2009 12:25 pm
And the rear shaft is out of time. Pull the spline out and spin it 90 degrees so the uni yolks line up
Post Posted: Fri Jun 12, 2009 2:13 pm
What ScrawnC said!
Post Posted: Fri Jun 12, 2009 10:22 pm
its most likely going to come down to axel wrap. even if your not pushing it hard its still going to be there. i jacked my car up the other day to cheak a nother problem i had. i had the enigne running in 5th gear at idel and i did quick stabs at the throttle and the axel was moving. i also have 5leafs in the back
Users browsing this forum: No registered users and 166 guests
