It is currently Wed Sep 30, 2026 10:07 pm
Post new topic Reply to topic  [ 30 posts ]
Post Posted: Tue Jan 05, 2016 8:57 am
Hi all,
So I'm about to get my hands on this little black sierra cheap, and as far as I'm aware the engine in it is shot. So I'm not going go muddle around like I did with the old sierra I had, I want to swap it out and make it a bit more drivable.
So what's better? A G16B 8v efi engine from a vitara or a G13BB efi engine from a Swift GTI?
to my knowledge the G13BB is a twin can where as the G16B is a single cam engine. I have heard people talk about the twin can engines having more grunt and so forth but I think old school in that there is no replacement for displacement.
The other thing I considered is the G16B is out of a Vitara which is also a 4WD which should mean it has a much better torque curve focused in the lower revs as opposed to the GTI engine having its power up top being a 2WD.
What's everyone's opinion? What's better? And is there any requirements for year matching on the engines to match emissions laws or any knicky stuff like that?
Cheers :D8-)
Vehicle: Which one?
Post Posted: Tue Jan 05, 2016 9:00 am
Everything being equal between the engines (price, condition, KMS) I'd take the G16B over the GTi G13BB every time. It has more power everywhere, and a much nicer torque and power curve down lower in the rev range.
Post Posted: Tue Jan 05, 2016 9:24 am
Just to be clear, the GTi motor is a G13B. The G13BB is the SOHC 16V jimny motor.
I too would choose the G16B over the G13B.
Post Posted: Tue Jan 05, 2016 9:39 am
Okay thanks guys the G16B it is then. My next question, is does it matter if its the 8v or 16v engine? I know the 16v G16B's are raved about among vitara owners in the LWB vitaras as having a bit more grunt.
I'm pretty sure if I remember right the 8v was only in the SWB and the 16v was only in the LWB.
Will either engine fit?
Vehicle: Which one?
Post Posted: Tue Jan 05, 2016 9:43 am
8v EFI engines exist, but aren't exactly common. I think you might be thinking about the carby 8v G16A in the SWB vits.
Post Posted: Tue Jan 05, 2016 9:44 am
All G16b's are SOHC 16v EFI.
All LWB 1.6 Vitaras are g16B
G16A's are almost all carb and 8v*
Swb Vitara went to G16B around 1994/1995.
*there are some Japanese import G16A's which are 16V.
Post Posted: Tue Jan 05, 2016 10:00 am
Ah okay so most efi G16B's are 16v no matter if they are fromma SWB or LWB. Alright that makes it easy. So if I can't find a low km G16B and I want to rebuild it, what's the best place to get a rebuild kit for one? ACL would be my first thought but their website doesn't list a G16B only the swift M16A engine.
Is the low range kit any good?
Post Posted: Tue Jan 05, 2016 10:28 am
I don't believe there is any point rebuilding a G motor. The cost of the machining is prohibitive. Just buy a low KM baleno if you need a new long motor.
Post Posted: Tue Jan 05, 2016 10:38 am
The baleno is the same 16v G16B engine?
And seeing I will need to pull the loom ecu injectors etc etc out of the donor car, it will also need to be a manual? Or can I use an auto engine?
Post Posted: Tue Jan 05, 2016 11:24 am
Long block is the same. Baleno has different manifolds, loom and some sensors, and you'll need to swap to a Vitara cam to retain the Vitara distributor.
Vitara manual and auto ecu's are the same, Vitara uses a separate transmission control computer.
Baleno has a different computer for manual and auto.
Post Posted: Tue Jan 05, 2016 12:03 pm
So it would be easier to find a vitara engine? But if I can't find one there is a way to put a baleno engine into the sierra.
Post Posted: Tue Jan 05, 2016 12:18 pm
Yes Vitara is the easiest swap, Baleno distributor g16B is the hardest/messiest.
Coil pack Baleno with a Jimny inlet manifold is the neatest/newest
Post Posted: Tue Jan 05, 2016 2:55 pm
Ah okay the baleno engine jimmy manifold sounds the best option. How hard are the coil pack baleno engines to get a hold of? I'm assuming they are in the later model balenos?
Post Posted: Tue Jan 05, 2016 3:09 pm
Pretty easy.
Post Posted: Tue Jan 05, 2016 3:58 pm
Alright cool. Thanks for the help guys, been on here for years and it never ceases to amaze me how helpful everyone is :)8-):)
Post Posted: Tue Jan 05, 2016 6:11 pm
Just had a closer look, its a 1985 SJ50 G13A .. This won't make any difference to the conversion? Its still a 5 speed box
Post Posted: Tue Jan 05, 2016 6:50 pm
No, it won't.
Post Posted: Wed Jan 06, 2016 10:28 pm
Is there a decent write up to be found anywhere about this coil pack G16B conversion? Want to know the finer details.. Like what throttle body to use? What AFM sensor to use etc etc.. I've heard little things like this make big differences in Suzuki engine conversions, for example the jimmy M18A conversion
Post Posted: Wed Jan 06, 2016 10:34 pm
That's the 1st year for 1.3litre / 5 speed - a better start point than a 1.0litre / 4 speed!.
The G16B won't bolt directly to the 5speed - adapter plate or jiggery pokery required (hole drilling, grinding).
Rgs, Michael
Post Posted: Wed Jan 06, 2016 11:15 pm
Haha yeah I did notice that! Its a lucky starting point :) yeah I'm aware of all the mounting kits inlcuding BenT's kit which is apparently the best. However I'm now trying to lay it out as this is the first thing I want to do to it once it is rego'd. I'll just have it sit for a while and I'll convert it :) it might take me a while to get it all the parts I need together but eventually I'll have everything I need :)
Post Posted: Wed Jan 06, 2016 11:24 pm
Okay so quick question guys seeing your all geniuses and all haha :P looking at the Vin plates, it says its an SJ50V which if I'm not mistaken is a hightop sierra... One problem. It ain't no hightop..
Any ideas?
Post Posted: Thu Jan 07, 2016 5:53 am
V just denotes van- hardtop.
You'd want to use the whole setup from the Baleno, injection wise.
Only difference will be if you can find a jimny intake manifold, this will eliminate the need to run coolant piping from the back of the head as per the fwd fitment.
All sensors throttle body etc will stay Baleno.
Post Posted: Thu Jan 07, 2016 8:16 am
Alright makes sense. Thank you :)
Post Posted: Thu Jan 07, 2016 8:32 am
Not a massive difference powerwise between jimny g13bb and baleno g16b
Both are good upgrade, g13bb is much easier for the novice
Vehicle: Drover pickup turk
Post Posted: Thu Jan 07, 2016 10:55 am
Coilpack Baleno into Sierra -http://auszookers.com/forum/viewtopic.php?f=17&t=6423
I like the tuna here
Vehicle: suzuki.sierra.88
Post Posted: Mon Nov 14, 2016 7:42 am
Not all LWB 1.6 Vitaras are G16B.
I had a LWB G16A EFI which I wrecked to run in my Sierra.
Does anyone know if there is a physical difference in the Ben T 1.6 adaptor plates between Sierra or jimny 1.6 conversions? Will a jimny kit also fit a G16B to Sierra 5 speed is what I'm asking?
Thanks
Post Posted: Mon Nov 14, 2016 7:51 am
Yes I know there a tiny number of g16A 16v LWB vitaras. (They're a pain) Considering the confusion the engine numbering conventions were causing the OP I didn't want to muddy the water any more.
Yes the g engine jimny conversion plate should be the same as a sierra one.
Post Posted: Mon Nov 14, 2016 9:47 am
Yeah, I was just being a dick.
Thanks for the info on the plate. Appreciate it.
Post Posted: Mon Nov 14, 2016 12:05 pm
The jimny conversion kit will come with a different engine mount adapter for the driver side.
Besides that, its the same I believe.
Post Posted: Mon Nov 14, 2016 12:33 pm
That's why I only mentioned the plate.
Users browsing this forum: No registered users and 169 guests
