It is currently Mon Sep 21, 2026 5:34 pm
Post Posted: Thu Jun 11, 2009 2:30 pm
Looking at these. http://www.theobd2shop.com.au/MS309.html
are '99 jimmys OBD2 compliant
Suspect the crank angle sensor is dicky from other websites. cuts out when hot under bonnet.
Will this meathod pick up codes?
http://www.btinternet.com/~j_holland/pages/diag.html
Is sensor easy to replace.
Post Posted: Thu Jun 11, 2009 2:42 pm
Yes, they should be OBD2 complaint. The plug will be close to the steering column and it looks like this
It will read any error codes that have been logged. It does sound like a cam/crank sensor.
Post Posted: Thu Jun 11, 2009 9:30 pm
http://www.scangauge.com.au/
Very good these are. I have one and it works a treat.
Post Posted: Thu Jun 11, 2009 10:17 pm
mine only has the small 6 pin connector left, anything i can use ?
Vehicle: Currently vehicle-less
Post Posted: Thu Jun 11, 2009 10:20 pm
Bruce,
This may be a stupid question, but can these devices be coded to act as a digital speedo, modified for larger tyres? IE can one be fitted and have a new gauge created to act as speedo*1.11 or something?
It looks like a pretty handy little device for the price.
Post Posted: Thu Jun 11, 2009 11:42 pm
Yes mate they can, All instructions are in ther. I use it for speed all the time. Happy to show you how they work mate. They are great
Post Posted: Thu Jun 11, 2009 11:45 pm
I also use it for Air intake temp, Water temp all at the same time on the same screen. Love this little machine.
I got a code error and it picked it up straight away, so I looked the error code on the net and a very simple fix was had.
You can set it up for distance to empty, ave speed, lts per hundred etc. Great, great play toy. :-)
Just check that it will work on your car first.
They are just a simple plug in and set it up and it's all good.
Post Posted: Thu Jun 11, 2009 11:56 pm
Yeah, definately sounds like it could be worth having. The fiance would find it much easier to drive with an accurate gauge, and I am not super keen on permanently having a big bulky gps smacked on the windscreen.
I couldn't find any info about compatibility with jimnys though.. tried the google search and ended up with endless results of foreign language pages
Post Posted: Fri Jun 12, 2009 1:02 am
Email them mate. They are good to deal with.
Post Posted: Fri Jun 12, 2009 1:21 am
Ah ok will do. Cheers
Post Posted: Fri Jun 12, 2009 12:47 pm
parfittron. can you post their reply please. [bulk discount?]
Post Posted: Fri Jun 12, 2009 1:34 pm
no worries
Post Posted: Mon Jun 15, 2009 4:40 pm
These things sounds pretty good.
It says it's compatible with the 2003 GV so should work.
if you're going to do a group buy pls count me in.
2002 SWB GV
Lifted and Locked
Users browsing this forum: No registered users and 187 guests
