| Jinny 4x4 not engaging http://auszookers.com/forum/viewtopic.php?f=5&t=52242 |
| Author: | bailey.robey [ Sat Apr 02, 2016 9:38 am ] |
| Post subject: | Jinny 4x4 not engaging |
Hey guys was just wondering what i could do to fix my 4x4, it wont engage not manual hubs and i have checked all the lines im pretty sure just dont know what it could be any help would be much appreciated Cheers ![]() Sent from my SM-N9005 using Tapatalk |
| Author: | Gwagensteve [ Sat Apr 02, 2016 9:49 am ] |
| Post subject: | Re: 4x4 |
First things first Is the front driveshaft spinning when you put the shifter into 4WD? If yes, then it's not the transfer case. You can check this by putting the car in 4WD when stationary and trying to turn the front driveshaft. If it DOESN'T turn, the transfer case is engaged. What do you mean "not manual hubs" do you mean it has stock auto (vacuum actuated) hubs? if so these are problematic and at 17 years of age will need a service or replacement with reliable manual hubs. If you mean "it's not the manual hubs" then blowing out the lines won't help, you may have other issues with the front end. A bit more information in the question would have helped us more. MOD: Edited to make sense |
| Author: | Joe [ Sat Apr 02, 2016 12:44 pm ] |
Gwagensteve wrote: You can check this by putting the car in 4WD when stationary and trying to turn the front driveshaft. If it turns, the transfer case is engaged. If it's engaged shouldn't it not turn |
| Author: | Gwagensteve [ Sat Apr 02, 2016 12:46 pm ] |
Ah yes, my bad. I knew what I meant. |
| Author: | Scrawny [ Sat Apr 02, 2016 1:14 pm ] |
Joe wrote: Gwagensteve wrote: You can check this by putting the car in 4WD when stationary and trying to turn the front driveshaft. If it turns, the transfer case is engaged. If it's engaged shouldn't it not turn Gwagensteve wrote: Ah yes, my bad. I knew what I meant. Edited to make sense |
| Author: | bailey.robey [ Sat Apr 02, 2016 4:30 pm ] |
| Post subject: | Re: Jinny 4x4 not engaging |
So if the drivehshaft turns its not engaged? Sent from my SM-N9005 using Tapatalk |
| Author: | Gwagensteve [ Sat Apr 02, 2016 5:01 pm ] |
If the transfer is in 4WD and the front driveshaft can be turned freely then the transfer isn't engaging 4WD. If the driveshaft can't be turned but there is no drive to the wheels the problem is diff/hubs Are you still running the factory vacuum actuated hubs? Steve. |
