http://auszookers.com/forum/
Grand vitara transfer case ratios
http://auszookers.com/forum/viewtopic.php?f=5&t=52294
Author:  2000 gv [ Mon Apr 11, 2016 4:00 pm ]
Post subject:  Grand vitara transfer case ratios
Does anybody know if 98-05 grand vitara auto/manual transfer cases are interchangeable and if they are the same ratio? I know that auto t-cases for the m series jimnys are a lower ratio to the manual so wondering if the grand vitaras are the same? Cheers
Author:  Zook_Fan [ Mon Apr 11, 2016 4:21 pm ]
Post subject:  Re: Grand vitara transfer case ratios
Transfer cases are the same ratio and no they are not interchangeable between auto and manual.
Author:  Gwagensteve [ Mon Apr 11, 2016 4:36 pm ]
I thought auto and manual had different input splines?
Author:  Zook_Fan [ Mon Apr 11, 2016 4:48 pm ]
Yeah they do. The manual input is larger in diameter and a lot longer than the auto.
Author:  2000 gv [ Mon Apr 11, 2016 6:13 pm ]
Ok thanks for the info guys
Author:  fordem [ Mon Apr 11, 2016 10:01 pm ]
It's my understanding that the differences exist only on the V6 transmission/transfer cases - I've been led to believe that on the 2.0 & 1.6 engined Grand Vitaras the transfer case is the same on both manual & automatics.
Author:  scottiej [ Tue Apr 12, 2016 1:36 am ]
I'm pretty sure the 2.0 and 1.6 splines are the same, I can check later, I have a couple of old manual 1.6 Tcases and one out of an auto 2.0
Author:  Zook_Fan [ Tue Apr 12, 2016 6:15 am ]
That is correct as well. It is the manual v6 transfer that is unique, the auto is the same as the older models.
