It is currently Mon Sep 21, 2026 1:03 pm
Post Posted: Mon Jun 15, 2009 11:57 pm
probably sound like a total dickhead. but on the dip stick where should the oil level be on a g16b.
and whould too much oil cause low oil pressure?
Post Posted: Tue Jun 16, 2009 12:49 am
There are two dots or two lines. Not below one and not above the other.
And yes your are a dick head for not knowing. :P
Post Posted: Tue Jun 16, 2009 3:11 am
too much oil would only cause low pressure if its WAY too high and the crank is hitting it making it foam up. Too low is way more common.
Also, I know its probably stating the obvious but make sure you're on a LEVEL surface when you check it...
Jester Racing- Who says you cant go mud racing in
Users browsing this forum: No registered users and 100 guests
