It is currently Wed Oct 21, 2026 4:18 am
Post Posted: Tue Jun 16, 2009 1:05 am
i have tried searching and been thro so many treads with little info
so thought i would pm people asking also no replys
so here we go i have found myself a 93 model gti engine with 130,000ks on the clock 4 $800 and he will help me with any other parts i may need 4 this engine like return lines fuel pump ect
well i have found 1 adapter from suzi sport 4 $395 but is there a cheaper option asi recon thats a bit of a rip off
also what dizzy would u run with this adapter can u still run the standard gti dizzy or do u have 2 mod anything
i have a sj80 what do i have 2 do 2 run a return line 4 the injected engine
is there any other little things that have 2 b done 2 make things fit does it clear the break booster fine ect
um what about what flywheel do i have 2 run and what clutch correct me if im wrong but i should run the oringal fly wheel and clutch 4 a sierra
ok fuel pump will the what did u guys do here did u run a pump in or out side ya tank if so what pump did u use
and is there anything i have forgot so far p.s i dont have 2 worry about wiring i have an auto sparky as a mate lol isnt costing me shit also while im here should i run a different computer or will the oringinal 1 b fine
just wanted 2 double cheak
lesspostingmorewheeling
Post Posted: Tue Jun 16, 2009 1:20 am
if you got a mk2 or mk3 motor you can't use the angle drive kit anyway your best bet would be a mazda gtx distributor cap and rotor
use the standard sierra clutch flywheel and starter
in a coily tank i think people use vitara in tank pumps
Post Posted: Tue Jun 16, 2009 1:24 am
ive got ahold of suzi sports and they recon the adapter fits the 93 model so i dont know if hes talking out his ass or what p.s will i need 2 cut anything out 2 allow room 4 the dizzy
Post Posted: Tue Jun 16, 2009 2:50 am
i'm not too sure chinny used a mk3 motor and couldn't use the right angle adaptor either way (using 323 dizzy cap or right angle drive) you shouldn't have to touch the firewall
Post Posted: Tue Jun 16, 2009 3:41 am
but if i hav 2 remove the dizzy i hav 2 drop the engine
right
Post Posted: Tue Jun 16, 2009 3:51 am
that is the downside but they aren't that heavy :lol:
Post Posted: Tue Jun 16, 2009 11:38 am
PM Joeblow, he might be able to help you with a dizzy drive angle adapter.
It should have a return line already, just use that.
Not that i've read, have a look at Chinny's thread and examine the pics, you should be able to get a pretty good idea of the fit. I have a GTi engine at home and the intake manifold doesn't look that much bigger than that of a SOHC 16v and they fit fine.
If you're using your stock transmission, use the stock clutch and flywheel.
If you want to do it on the cheap just run a EFI pump. If you want to do it properly put in a surge tank, fed by a low pressure pump. Then your EFI pump is fed from the surge tank.
Swap the water pump for a Sierra water pump so you can run the Sierra fan, or run a thermo fan. You'll also want to swap over the Sierra sump and oil pickup. Have you thought about exhaust? There are no off the shelf solutions, best bet is to get a set of Sierra extractors modified with a GTi flange.
Make sure you post up some info about your swap to help out the next guy that wants to do it.
Just one more thing about the dizzy. If you are considering going for an aftermarket ECU you should look at ditching the dizzy altogether. Most after market systems can control ignition by using crank/cam position sensors and firing coil packs directly. I think whether you'll be able to do this or not will come down to your auto leccy mate, so ask him what he thinks.
Post Posted: Tue Jun 16, 2009 9:57 pm
yeah thanks alot 4 the info ay
i have been looking in 2 doing away with the dizzy all 2geather and yeah b looking at about 1000 bucks 4 the comp then prob cost me another 100 2 install it
plus then ya got 2 buy a 4 stack coil
and yeah 4 sure i would let every1 else know the info on it as like i said i did a big seach and couldnt find fuck ll info on this
going 2 run my quad carbs on the stock engine see how that goes first then if im not happy im selling the engine 2 chris and going with the gti engine
just wanted 2 weigh up the costs ect and what i will gain and have 2 do 2 get the gti engine in as apossed 2 just putting the stage 2 cam ported head and quads on my engine
as i can get my cam re ground 4 250buckks and another 250 bucks 4 porting
and for exhaust i have 2 sets of extracters here 1on the car and a spare set so no probs there
Post Posted: Wed Jun 17, 2009 11:28 am
Next time don't bother searching, just post up a thread.... no one will get grumpy :D
Vehicle: jimny
Post Posted: Wed Jun 17, 2009 11:33 am
hey nandor, how did you go with the quad carb cable after i posted you those links on the 4wdmonthly shit forum
Vehicle: LJ20 LJ50
Post Posted: Wed Jun 17, 2009 12:59 pm
Hey keep that up and I think you may have to get on the bus back to outers
Camels have nice toes
Post Posted: Wed Jun 17, 2009 1:26 pm
Ok, I take that back..... Only Jock will get grumpy!! :P
Post Posted: Wed Jun 17, 2009 11:05 pm
yeah got my cable yesterday cost me 76 bucks put in the the carbs and lines up great will b put in on my days off on thursday and friday next week
Post Posted: Mon Nov 21, 2011 3:56 am
Got anymore info on this?
Users browsing this forum: Google [Bot] and 259 guests
