It is currently Sat Sep 26, 2026 12:51 pm
Vehicle: 1973 lj50 fully restored
Post Posted: Mon Apr 25, 2016 8:39 pm
I was wondering if anybody can tell me if the 800cc motor can be bored out to 1 litre and if the block is the same otherwise as I
have several 800 blocks and a destroyed 1 litre.
Thanks in anticipation DR.
Vehicle: zook
Post Posted: Mon Apr 25, 2016 8:56 pm
The f10a has a 65.5mm bore. (wiki). If you could get the 62mm bore f8a to 65.5mm you would still only get to 889cc with the F8a cranks' 66mm stroke.
That is a fair bit to shave off the liners...
Post Posted: Mon Apr 25, 2016 9:18 pm
The bore casting is slightly thicker on the f10a I think so it might not be possible to bore an F8a block out enough?
As for the other parts it should be simple. You would just need the 410 crank and pistons fitted to get to 970cc.
Some info for you
As you can see the only difference in the cranks is the stroke so they can be swapped, the extra capacity is also made up with the piston compression height, I haven't found the conrod lengths yet but the F8a and F10a use the same conrods.
Sj410 con rod 12160-73001
Lj80 con rod 12160-73000
Post Posted: Tue Apr 26, 2016 7:48 am
But why bother Just get a F10 motor
Post Posted: Tue Apr 26, 2016 8:47 am
Unless you have the tooling etc, it probably wont be cost effective.
If the f series engines are like the g series, the rebuild probably wont last a real long time either.
Post Posted: Wed Apr 27, 2016 6:23 pm
Thanks for all the info a f10a motor turned up at the Maffra swap on Sunday it is in good order only needs new set of rings .Thanks heaps again for the info I never cease to be amazed at how much you guys know.
Users browsing this forum: BlueSuzy and 250 guests
