It is currently Mon Sep 28, 2026 1:53 am
Vehicle: 2000 Suzuki Grand Vitara
Post Posted: Mon May 02, 2016 10:38 am
Hi All.
Looking for advise as to where / how to mount a custom rear bar ( heavy ) on my
Sierra SJ50 1988. Any photos / ideas of your rigs would be much appreciated.
Thks
Chris.
Post Posted: Thu May 05, 2016 8:59 am
10mm flat plate between the tow bar and chassis. Just add longer grade 8.8 bolts
Post Posted: Thu May 05, 2016 4:51 pm
Personally, I'd be trying to make a rear bar as light as possible. The added weight isn't helping the car one bit and there's very little added protection provided by a rear bar due to the rear overhang being so short.
Post Posted: Thu May 05, 2016 6:23 pm
I mounted my led lights on my tail gate and just had a single pipe welded across the 2 10mm plates on mine . It was only there so i could reverse by feel when turning around on narrow dead end tracks
Post Posted: Thu May 05, 2016 6:25 pm
^This. pointless having a heavy rear bar when you back into a tree and smash the tailgate. Cars with very vulnerable quarters and long rear overhang can benefit from a rear bar, so not a sierra then.
Post Posted: Fri May 06, 2016 8:20 am
Thks for the feed back guys
Post Posted: Fri May 06, 2016 1:15 pm
I put a pipe through the xmember and welded plates onto it.
Bolted the rear bar to the plates.
Bar had a swing away to carry a full sized spare and incorporated a hitch receiver into it.
In hindsight, it was a prime example of a pointless sierra mod.
It was stupid heavy and offered no real functional improvement.
Car was more capable with it removed.
Stock rear bumper ftw
Stock tow bar is good for towing.
I unbolt it when not towing. 2 bolts vs pin and a bolt with lock nut on a hitch receiver.
