It is currently Mon Sep 21, 2026 10:55 pm
Post Posted: Tue Jun 16, 2009 3:44 am
Does anyone have a 2.5 or 2.7 V6 block that they can measure the oil filter gasket contact area on please.
What I am after is the inner & outer diameter of the circular surface where the oil filter gasket seals against the housing on the block.
Thanks.
Post Posted: Tue Jun 16, 2009 12:50 pm
Just go to Super cheap and look at a filter there and add a couple of mm
Steve W
Post Posted: Tue Jun 16, 2009 6:39 pm
Great idea, but I have looked at two already and they are different, so of no use.
Thanks anyway :-)
Post Posted: Tue Jun 16, 2009 7:57 pm
what are you planning on doing? fitting a remote filter setup?
Post Posted: Tue Jun 16, 2009 9:12 pm
That is the long term plan (when I can afford it) but for now I will settle for a longer (taller) filter that I have some chance of getting a wrench onto, or getting my hands around it to loosen / tighten. Bigger diameter cannister will help too.
There are many longer ones with the same thread (3/4" X 16 UNF), ADBV, similar psi relief valves etc, but I need to know what gasket size I can get away with.
I would like to use the common old Z9 (or a better quality equivalent like B2 Baldwin) because it is 140mm long vs 95mm one I have just put on. Bloody thing is going to be a real pain to get off, and I do not want to put another one like that on.
Post Posted: Tue Jun 16, 2009 9:31 pm
Who the fuck decided to put the oil filter there between the engine mount, the cross member and the exhaust?!? Bloody things are impossible to remove without getting oil everywhere! :x
I bet the engineer/trained monkey who designed that has a good laugh every time they think of someone trying to change a filter.
It is the second worst oil filter location I have seen after a Mitsubishi colt! :roll:
Post Posted: Tue Jun 16, 2009 10:46 pm
Well said mate!!!! My feelings exactly. The only one I have seen worse was an early model Nissan Exa Turbo.
Vehicle: 1993 Sierra 1.6 efi Vit motor,
Post Posted: Tue Jun 16, 2009 10:51 pm
They're designed by a contortionist, because you need to be one just to get at it, especially the current model GV! :? :? :?
Users browsing this forum: Google [Bot] and 207 guests
