It is currently Fri Oct 02, 2026 9:01 pm
Post Posted: Sun May 15, 2016 11:57 am
Does anyone have a NGV with a factory fitted reverse camera? Where is it fitted (yes, I know, it's on the back somewhere)? If possible could you post a picture please.
Post Posted: Sun May 15, 2016 6:04 pm
It sits just above the numberplate attached to the underside of the bumper between the numberplate lights.
Post Posted: Mon May 16, 2016 12:21 am
Thanks - any chance of a picture? Is the number plate centered on your car?
What you have described sounds like exactly where I mounted the reverse camera on my '98 GV, and I find that somewhat low - I need to fiddle with the camera angle, to see if that will help any, but, right now, the "distance" guide lines are pretty much unuseable.
The reason I asked about the NGV is my daughter has just acquired an Escudo, with that body style, and she wants a reverse camera - it came with an aftermarket dual DIN, nav system which I'm pretty certain can take a camera, so I just have to find one and fit it.
Post Posted: Mon May 16, 2016 4:17 pm
Number plate is centred. This is where they go from factory.
Post Posted: Mon May 16, 2016 11:33 pm
Thanks much - I'll have a look at her car in a couple of days - see if I can use the same location.
You seem to be using an aftermarket camera there, does your's have the distance scale lines? Are they useable for you?
Post Posted: Tue May 17, 2016 8:25 am
Yes it gets added by the dealer. It seems pretty accurate, well its better than the parking sensors on my old Work car (Holden Cruze)
Post Posted: Tue May 17, 2016 11:31 pm
I'm in Florida, visiting with my sister, and when I came in yesterday, there was a NGV in the driveway across the street - with the number plate, below the bumper, offset to the left - which is where I think it is on the Escudo.
Post Posted: Sat May 21, 2016 10:19 pm
I'm back in Guyana, my daughter stopped by yesterday, and yes, her number plate is offset to the left - I wonder how much of a difference that would make to the image...
Users browsing this forum: Google Adsense [Bot] and 114 guests
