| Aw4 flex plate and torque convertor, whats going on here? http://auszookers.com/forum/viewtopic.php?f=5&t=52521 |
| Author: | jdk81 [ Sun May 22, 2016 4:48 pm ] |
| Post subject: | Re: Aw4 flex plate and torque convertor, whats going on here |
The tc probably isnt seated correctly It can take a lot of wiggling and jiggling to seat it correctly. If you do it up tight when its not seated it can break shit. |
| Author: | henno [ Sun May 22, 2016 5:12 pm ] |
^^ What he said. It needs to seat properly or the pumpy thingy won't do pumpy stuff and stuff goes bang. There's more than one spline thingy you need to mate up with the converter doo-dad. I think Atari had some AZ tech around the place that went something line "One bang-click bad, two bang-clicks good" when seating it. I'd find the post but I'm trying to embrace my inner noob. Do you even search.php bro?
| Author: | drdave [ Sun May 22, 2016 6:37 pm ] |
The more info I get the more confused I get.... I got 2 click bangs but I reckon it could go back further, if I just knew if the flex plate was the right way around I would know for sure. Yep I did a search but I have no idea what .php is! My tech knowledge is like my car knowledge, it leans towards the old stuff (aka I'm also building a 1958 Chrysler royal and a WB tonner). Thanks guys, I'll go and play with the torque convertor some more, seems that may be the issue. There's still room for it to move back, I can fit my finger behind the torque convertor between the gearbox |
| Author: | Scrawny [ Sun May 22, 2016 7:16 pm ] |
Push the torque converter while spinning it. Can take 7-8 (or more) full rotations to get it to seat right in |
| Author: | drdave [ Mon May 23, 2016 5:28 am ] |
Thanks Scrawny, seems I may have given up too early. I'll have another go at it today |
| Author: | MrRocky [ Mon May 23, 2016 7:59 am ] |
Yup give it turn while pushing it. |
| Author: | drdave [ Mon May 23, 2016 9:23 am ] |
Well it looks like I might have more problems than I thought, it appears there should be a spacer on both sides of the flex plate and I don't have them. Does anyone know if this is correct? I've never had this much trouble with any of the cars I've worked on |
| Author: | Dmfelix [ Mon May 23, 2016 9:52 am ] |
this is the best pic of i've got of mine sorry
| Author: | drdave [ Mon May 23, 2016 10:14 am ] |
Thanks mate, looks like my flex plate is on the right way. Does yours have a spacer on the flex plate? I still cant get the convertor to seat in properly |
| Author: | Gwagensteve [ Mon May 23, 2016 10:19 am ] |
I haven't had an AW-4 apart, but trimatics defintiely do have spacers. I'd be surprised if the AW-4 didn't- the flex plate is quite thin and the spacers add clamping force. |
| Author: | atari4x4 [ Mon May 23, 2016 11:57 am ] |
henno wrote: ^^ What he said. It needs to seat properly or the pumpy thingy won't do pumpy stuff and stuff goes bang. There's more than one spline thingy you need to mate up with the converter doo-dad. I think Atari had some AZ tech around the place that went something line "One bang-click bad, two bang-clicks good" when seating it. I'd find the post but I'm trying to embrace my inner noob. Do you even search.php bro? ![]() one, two, three viewtopic.php?t=32817&p=604781
| Author: | jdk81 [ Mon May 23, 2016 12:27 pm ] |
Your flex plate is on correctly. Once again your TC is not seated correctly. Keep turning, wriggling and pushing. If it wont go you may have broken it trying to force it up with bolts. Here is isnt seated correctly. ![]() Here I think it is, but I cant be bothered lifting it out onto the bench to check for you. Its heavy, and theres lots of stuff in the way. ![]() When placing a ruler across the face of the bell housing the locating spigot is the outer most point of the whole torque converter and it is 3mm inside. When it's right you will realise once you had it assembled incorrectly before. It's a cubic assload easier to mount the auto and engine on a bench than in the car. |
| Author: | drdave [ Mon May 23, 2016 6:15 pm ] |
Thankyou for those pics, that really clears it all up for me. Seems I better clear the work bench, it might be a little easier than working on the ground. Hopefully I haven't broken anything but there's a good chance I have. Thankyou again for the help |
| Author: | drdave [ Tue May 24, 2016 2:58 pm ] |
Well it looks like I've broken something, I got the torque convertor almost all the way in and it pretty well locks up with only about an 1/8th of a turn movement. So am I missing something or is it buggered? |
| Author: | Scrawny [ Tue May 24, 2016 6:15 pm ] |
It should spin freely |
| Author: | drdave [ Tue May 24, 2016 6:21 pm ] |
Bugger, I cant seem to pull the torque convertor off completely either. Better start hunting up another one |
