| Author |
Message |
henno
Joined: Tue Jul 23, 2013 5:56 pm Posts: 2439 Location: Brisbane
Vehicle: Which one?
 Posted: Mon May 30, 2016 7:15 am |
In need of some good paint tech before I go squirting black stuff at metal things currently sitting in primer.
I really like the British Paint rattle guns after a solid AZ recommendation - not sure I could go back to anything else after using them - but with that in mind, what is the best paint to spit at bar work? Glossy something I assume, UV stabilised/resistant, easy to throw on and easy to touch up?
The bar work will cop a flogging, so touch ups will happen regularly. Something nice and thick and/or bash/scrape resistant would be good. What does everyone else use?
ozzycouch
Joined: Sun Sep 18, 2011 11:23 pm Posts: 256 Location: Maroochydore Sunny Coast
Vehicle: SWB Vit
 Posted: Mon May 30, 2016 8:05 am |
henno wrote: What does everyone else use? Rust, and when it's looking really bad, I drag it over some rocks to polish it up. I'm not sure of any thing that looks good after a few bush runs however the two pac on my front bar is holding up x1,000,000 times better than the spray pack on the sliders.
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Mon May 30, 2016 8:07 am |
I use black rust guard on mine, straight from the spray-can.
After 2 years or so it loses its gloss and goes a bit grey, but nothing a light re-coat doesn't fix right up.
The ease of touch-ups / re-coating is what does it for me. But then the paintwork on my sierra is poo, so the bar looking a bit ratty doesn't concern me too much.
henno
Vehicle: Which one?
 Posted: Mon May 30, 2016 11:27 am |
Has anyone ever used the John Deere Black Blitz Black stuff? Being UV stabilised and easy to squirt on sounds good to me, even if it is a little bit too "hot rod" hipster cool.
atari4x4
 Posted: Mon May 30, 2016 11:39 am |
Septone Bumper Bar Black
steve125
Joined: Sun Sep 05, 2010 11:58 am Posts: 427 Location: Melbourne
 Posted: Mon May 30, 2016 1:57 pm |
BlueSuzy
 Posted: Mon May 30, 2016 2:07 pm |
I normally go over my barwork with a file to smooth off the gouges, I then use Killrust black gloss enamel in the spraycan. It hides and blends welds in nice too as its a bit thicker than a $2can
henno
Vehicle: Which one?
 Posted: Mon May 30, 2016 2:10 pm |
That sounds rather perfect. I also plan to hit them with a file when needed. Does it go all powdery in the sun like just about everything else?
alien
 Posted: Mon May 30, 2016 2:24 pm |
Mine's never gone powdery, just dulls back to a matt finish and charcoal colour eventually. I just give it a wipe with a dry towel to get any big dirt/dust off it then another light coat using a piece of cardboard to shield things like the spotties / headlights etc as i go. Takes all of 10mins and lasts about a year before showing signs of dulling again. Mine's parked in full sun all year round too.
greenzook89
Joined: Sun Sep 06, 2009 11:30 pm Posts: 2591 Location: Ipswich
 Posted: Mon May 30, 2016 7:07 pm |
I used Barrier 2k on my front bar. Good UV and shiny. For my roof basket i used killrust matte black. Thats what I'll be using for all future barwork.
_________________ 31zook wrote: Makes me want something similar
watermouse
Vehicle: zook
 Posted: Mon May 30, 2016 7:48 pm |
2k Acrylic Urethane for longevity and gloss retention. The best I have used is Glasurit but Protec 2k is almost as good.
A 2k Polyurethane would stick better, hold gloss longer, but much harder to spray and fix.
For rattlecan, CRC Zinc Black on bare metal works well, good at inhibiting corrosion, dries fast and easy to touch up. Matte though.
henno
Vehicle: Which one?
 Posted: Mon May 30, 2016 8:08 pm |
Ease of touchups and ease of initial use pretty much rule out 2k options I think. I will be beating on this bar work every time I drive it.
A few good options here though, feel free to keep them coming.
GraphicX
Vehicle: 2000 Jimny
 Posted: Mon May 30, 2016 8:09 pm |
if you're painting stuff that's likely to cop bumps & worried about chipping you're best off using epoxy enamel, which kill rush in rattle cans just happens to be (of course powder coated is better).
BlueSuzy
 Posted: Tue May 31, 2016 1:21 pm |
henno wrote: That sounds rather perfect. I also plan to hit them with a file when needed. Does it go all powdery in the sun like just about everything else? Mine doesn't really see much sun. The rollcage has changed a little(still glossy when clean) and the bar work around, Most of it never gets old enough.. um..trees, rocks, dirt polish.
atari4x4
 Posted: Tue May 31, 2016 1:54 pm |
GraphicX wrote: if you're painting stuff that's likely to cop bumps & worried about chipping you're best off using epoxy enamel, which kill rush in rattle cans just happens to be (of course powder coated is better). Bumper Bar Black is flexy as fuck, my calmini stuff was panted 10yrs ago & only needed a freshen up when I built the blagon.
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Tue May 31, 2016 10:17 pm |
Reckon powdercoat would be strong enough?
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
 Posted: Wed Jun 01, 2016 7:00 am |
It's great until it's ground back to metal, then it's a pain to repair.
henno
Vehicle: Which one?
 Posted: Wed Jun 01, 2016 7:59 am |
Yeah, I think it's safe to say I am ruling out 2k and powder as options for my particular needs.
jono165
Joined: Thu May 27, 2010 12:01 pm Posts: 834 Location: Melbourne
 Posted: Wed Jun 01, 2016 2:20 pm |
