It is currently Thu Sep 24, 2026 1:34 am
Vehicle: suzuki sierra stockman ute
Post Posted: Tue Jun 21, 2016 9:11 am
last night I tried to change my 4wd gears from low to high now it is stuck in neutral, the gear box is working ok just not the 4wd box, is there a quick fix or a trip to the mechanics as this has never happened before, cheers warren
Post Posted: Tue Jun 21, 2016 10:04 am
Easy fix. Shift bush.
Get a new one and replace it, it's the nylon ring that the transfer case shifter seats in. They get flogged out.
Don't even need to remover the TF case to do it (although it's tight to leave it in)
Vehicle: SJ70 1993
Post Posted: Tue Jun 21, 2016 10:06 am
Sounds like your selector bushings have become mush.
I had same problem once in my sj70 not sure if the TC are similar. but i was able to insitu, go in from the top and remove the selector and install new bushes and put back togeter and it was good to go.
Edit: yes see above :)
Post Posted: Tue Jun 21, 2016 11:37 am
eBay ones below. Bear in mind these are very tricky to instal s they are very tough!! They do work however. I'm not sure about other suppliers.
http://m.ebay.com.au/itm/Transfer-Case- ... nav=SEARCH
Vehicle: SJ70 1993
Post Posted: Tue Jun 21, 2016 11:48 am
Yeah i think i used a hook and dolly to install it, put it in side ways and then pull it flush and hammered in place.....
Post Posted: Tue Jun 21, 2016 11:58 am
That's the go :)
Post Posted: Tue Jun 21, 2016 12:12 pm
Also here is an illustrated description of how to reset and install the bush - sometimes referred to a a "shifter Sheet":
http://bbs.zuwharrie.com/content/topic,1425.0.html
http://www.Zuksoffroad.com sells an indestructable brass unit for the WT Sierra (Samurai) around $15.00 (US) + shippping...
I hope that this helps
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Post Posted: Tue Jun 21, 2016 2:28 pm
If ya desperate, you can just pull the stick out, fool around with the selectors until ya get neutral, put the stick back in without the bush, and select gears mindfully.
bye
Post Posted: Tue Jun 21, 2016 2:43 pm
This^
I had an early non-swtich case 1l which you can't buy a shifter sheet for anymore. It got stuck in neutral and after that I always pulled the lever up when I shifted and it never got stuck again. Certainly buy a sheet and install one, just saying it's not the end of the world until you get one.
Vehicle: sierra
Post Posted: Wed Jun 22, 2016 7:59 am
This happend to my mates Sierra 2 weeks ago, the bush is mush, we got one off eBay for $8. Remove stick, put in new bush, put stick back in, drink beers.
Vehicle: Suzuki Sierra 1985 ute
Post Posted: Sat May 21, 2022 8:57 am
Hi guys, having the same issue. Have new bushes but how do I get the top bush on, does the stick come apart/unscrew? If so mines locked together tight. Any tips?
Users browsing this forum: Google [Bot] and 174 guests
