It is currently Thu Sep 24, 2026 6:48 am
Vehicle: 1999 Grand Vitara
Post Posted: Mon Jun 27, 2016 2:18 pm
hi guy's.
i have a j20a 99 GV auto with the alloy front diff housing. have found a 03 GV that had a h25a at the wreckers with a steel front diff complete. forgot to look if it was a manual or auto.
is this a complete swap over? or would i have to change the actual diff and pinion? same diff ratios?
also are the free wheeling hubs from the earlier vitara's the same as what my GV would use?
Thanks. :)
Vehicle: Which one?
Post Posted: Mon Jun 27, 2016 3:28 pm
The diff gears are likely to be different, unless it's auto.
And the free wheeling hubs are off the old Vits, yes.
Post Posted: Mon Jun 27, 2016 10:28 pm
thanks for your reply henno.
i guess my pinion, diff and shafts can be used in the steel housing?
Post Posted: Tue Jun 28, 2016 6:55 am
Yes, you'll need a diff shop to do the install.
Post Posted: Fri Jul 08, 2016 6:57 pm
Depending on what your trying to achieve as to what ya do.
Being a J20a Auto you would have 5.12 ratio gears. Auto V6 would have 4.8's Manual V6 will have 4.3
Best option is use your R&P on a Vitara center and have that installed into a steel carrier and housing from a Manual V6 GV. this removes all the Air engagement stuff from the GV front diffs.
Its recommended to get a diff shop do the install. You could do it yourself but you really need to know what ya doing.
What area you from?
Post Posted: Sat Jul 09, 2016 1:31 pm
Auto j20 will have 4.8
Post Posted: Sat Jul 09, 2016 8:52 pm
What area you from?
Well i was at the wreckers looking for a bonnet hinge when i seen the steel front housing and have read that they are a good upgrade in strength over the alloy housing. So thought i should look at getting it. I am putting free wheeling hubs on as well.
Hrmm.. they have a couple vitara's there too, that's what i am getting the free wheeling hubs off.
am in WA.
Post Posted: Sun Jul 10, 2016 8:58 am
Im not so sure about that.
Bohuler had a manual GV with the J20 and it had 4.8's
the diffs we put in it were from a J20 auto and they were 5.12's
Post Posted: Mon Jul 11, 2016 8:11 pm
Who knows then. The swb j20 gv i parted had 4.8
Vehicle: Which one?
Post Posted: Mon Jul 11, 2016 8:59 pm
Mine is 4.8
Post Posted: Tue Jul 12, 2016 8:43 pm
Maybe the SWB is different to the LWB.
