http://auszookers.com/forum/
Wiring kit for 1.6 ???
http://auszookers.com/forum/viewtopic.php?f=5&t=52751
Author:  Bennyzarb [ Mon Jul 04, 2016 8:52 pm ]
Post subject:  Wiring kit for 1.6 ???
Hey there
Is there anyone that makes wiring loom kits for a 1.6 vit motor to plug into a 1L loom in sierra ????
Author:  jono165 [ Tue Jul 05, 2016 9:43 am ]
Post subject:  Re: Wiring kit for 1.6 ???
If you have a whole 1.6 donor car you could swap in the vitara steering column and run the entire vitara loom. Gwagensteve and myself have done this, although mine was 1.3 to start with.
If you're running just an engine loom you can strip out what you don't need from the vitara loom and there's nothing that really needs to plug into the 1L loom. You'll just need to rewrite the instrument cluster plugs
Author:  Gwagensteve [ Tue Jul 05, 2016 2:09 pm ]
I would defintiely use the whole Vitara loom. The 1.0 loom is a much older and less reliable design.
Author:  rexhunta [ Tue Jul 05, 2016 2:43 pm ]
Done the same to 2 other cars, used the entire loom. Find less gremlins and neater loom.
Author:  Bennyzarb [ Tue Jul 05, 2016 7:43 pm ]
Wouldnt it be easyer to go haltec computer ? And just get an auto electrician to wire it ?
Author:  Gwagensteve [ Tue Jul 05, 2016 8:24 pm ]
No. Because the dyno time will cost more than the car is worth.
