hello everyone,
this is more of a few questions for those who have used killa kustom kables loom to do there swift GTi conversion into sierra. I have contacted them a couple of times over the last week via facebook messages but haven't received a reply yet, was gonna call them yesterday but got held up at work latter than expected and didn't get a chance to, so thought i would ask on here as i know there are a few of you who have used them.
so what i need to know is the part of the loom that joins into the ignition barrel there are five wires
From there instructions, the brown goes to the tacho signal, orange goes to the battery positive, pink goes to ignition positive and the black goes to the star signal. I need to know what the small purple on goes to as it is not mentioned in the instructions.
also need to clarify which position of the ignition barrel to the corresponding wire would i join the pink wire to. now I am working of the wire directly of the back of the ignition barrel. I have
White - constant power - orange (Killa loom)
Black/yellow strip - Start - Black (Killa Loom)
White/Black Strip - Accessories -
Black/White strip - on -
Where have people installed the ECU. I don't want to have it in the engine bay, but for me to get it in the cab and out of the way i need to extend the loom 500mm to 1m and/or add a hole to the firewall (depends on Engineers answer as to whether i do that) behind the battery.
to end it all off at the moment (till the next issue arises) there is the purple/yellow strip wire which has no mention anywhere, can anyone tell me what it for
All help is totally accepted and I am grateful to those that can help
