| Weber carby anatomy, rebuild and tuning http://auszookers.com/forum/viewtopic.php?f=5&t=52823 |
| Author: | HarryHoudini [ Fri Jul 15, 2016 8:52 pm ] |
| Post subject: | Re: Weber carby anatomy |
Thanks for making the effort,great stuff. |
| Author: | bumstein [ Fri Jul 15, 2016 9:35 pm ] |
No worries!! It's not a comprehensive A-Z of the carby but it might come in handy for someone. I have had the intention to do the same for the stock carby, even have most of the pics but haven't had the time to compile them. This way if I do it as I go it's easier for me |
| Author: | bumstein [ Sat Jul 16, 2016 1:59 pm ] |
| Post subject: | Weber carby anatomy, rebuild and tuning |
Next episode, starting the lower half. ![]() Remove the air corrector jets at the top of the carb throttle body. Left one is the primary, right is the secondary. ![]() You can then (probably) remove the emulsification tubes. A small screw driver or Allen key can fit in the tube to gently wiggle it out (gravity assisted). They may be more difficult than this method allows, if be keen to hear others methods of getting it out. To get the tube out my secondary side I had to wait until I'd removed the venturis and pop it out with a fine tipped pick. ![]() Primary and secondary main jets can be removed with a flathead screwdriver. Primary and secondary are the same orientation as the air corrector jets. ![]() Remove the primary idle jet and O ring from adjacent to the accelerator pump. There's also one on the secondary side, opposite the primary. ![]() ![]() Remove accelerator pump jet and pump delivery valve assy, note the placement of washers ![]() ![]() ![]() The fuel deliver venturis slide out upward. Take note of which side the fuel entry hole is as if they are put back the wrong way fuel won't be able to enter the venturis and no fuel will be delivered into the barrels. ![]() http://s688.photobucket.com/user/jflock ... 0.jpg.html Remove the full power needle assy at the bottom of the float chamber. ![]() ![]() Undo the four screws holding the accelerator pump assy together, remove the cap, diaphragm and Spring. As you can see mine wasn't the cleanest assy, perhaps the source of the problems I'm having with this carb at the moment!! Gunge has found its way in and festered in there ![]()
| Author: | bumstein [ Sat Jul 16, 2016 2:01 pm ] |
![]() More to come.. Choke assy next. |
| Author: | bumstein [ Sat Jul 16, 2016 5:04 pm ] |
Your now ready to clean a whole bunch of parts!!! I will also remove the Pump Discharge Blanking Needle as I've got crap residing in that wee tube. Photo of that when I get home and have the correct size screwdriver. |
| Author: | bumstein [ Sat Jul 16, 2016 7:55 pm ] |
Pump Discharge Blanking Needle as promised ![]()
| Author: | cairns27 [ Sat Jul 16, 2016 8:27 pm ] |
Like. bye |
| Author: | bumstein [ Sat Jul 16, 2016 8:50 pm ] |
Thank you Bye |
