It is currently Sat Sep 26, 2026 4:37 am
Vehicle: sc100 se416 mightyboy
Post Posted: Mon Jul 25, 2016 11:12 pm
Was just throwing a g13 engine back in a sj80 today and noticed the size difference on g13a (1324cm3) g13b(1298cm3).
I sure someone will answer this easy as to where the difference lies, just curious that's all.
Post Posted: Tue Jul 26, 2016 4:09 am
The stroke is longer, the bore is the same.
Post Posted: Tue Jul 26, 2016 8:39 am
So just the crank is a little different, block height remains same?
Post Posted: Tue Jul 26, 2016 10:47 am
Let me rephrase that - the difference in capacity comes from a longer stroke, and whilst I'm not 100% certain, I believe the block crank & rods are different.
Post Posted: Tue Jul 26, 2016 11:55 am
Fun fact - it was changed so the swift could race in rally (under 1300cc).
Post Posted: Tue Jul 26, 2016 3:14 pm
Some may say its not noticeable but i prefer the 1298cc donks
Just have a nicer feel through the revs
Post Posted: Tue Jul 26, 2016 6:41 pm
block is bigger? by how much? I used the g13b and it had square timing belt and I changed to round? problem?
Post Posted: Tue Jul 26, 2016 7:00 pm
Just measured block, they are same.
Post Posted: Wed Jul 27, 2016 1:05 am
The belt profile needs to match the pulleys - square tooth belt with square tooth pulleys, no problem - round tooth belt with round tooth pulleys, no problem - round tooth belt with square tooth pulley (or vice versa), PROBLEM.
You'll find many such minor differences, some of the crank pulleys are four hole, some are five...
Vehicle: Which one?
Post Posted: Wed Jul 27, 2016 7:05 am
Holden famously did the same thing for Group A homologation: the 308 becoming 304ci to be under the 5L capacity limit.
Users browsing this forum: No registered users and 439 guests
