http://auszookers.com/forum/
Sierra leaning to drivers side
http://auszookers.com/forum/viewtopic.php?f=5&t=52891
Author:  cyprus73 [ Sat Jul 30, 2016 11:56 am ]
Post subject:  Sierra leaning to drivers side
Hi all.
Need some advise. I have an 88 WT Sierra and it leans on the drivers side.
I have determined it's something to do with the leaf spring shackles. Passenger side are parallel straight up and down.
The drivers side are angled at approx 45 degrees. Any ideas why and how to fix ?
BTW leafy springs have been changed and brand new. It was the same with the old springs. Approx 20-25mm difference.
Checked the cache and under body and all likes fine. The distances between the body and cache are the same all the
way around. Really got me puzzled.
Thks in advance Chris
Author:  Gwagensteve [ Sat Jul 30, 2016 12:15 pm ]
Post subject:  Re: Sierra leaning to drivers side
whats the cache? I've never heard this word associated with a car before. Oh - just realised - you mean chassis?
In any case, It's nothing to do with the shackles, the shackles are just reflecting the lower ride height (the leaf springs lengthen as they compress, which is what changes the shackle angle) The distance from the axle to the bumpstop will be different left to right.
Sierras are significantly heavier on the driver's side. The driver's side spring should have more arch to compensate. It's possible you've installed the passenger's side spring on the driver's side. Try swapping springs left to right on the front, this often fixes the problem.
Some lean to the right is fairly common though. In my own car (which has been converted to coil springs and uses Vitara rear springs in the front) I required a 20mm spacer on the driver's side to make the car sit level.
Author:  alien [ Sat Jul 30, 2016 2:02 pm ]
It's called "suzuki lean" if you search it up top you'll find a heap of info on it.
Author:  cyprus73 [ Mon Aug 01, 2016 2:11 pm ]
Hi All.
Can i compensate for this with longer shackles on the drivers side to correct this?
The leaf springs are only 2 weeks old.
Thks
Chris.
Author:  Gwagensteve [ Mon Aug 01, 2016 3:04 pm ]
No. Definitely not.
Swap the springs left to right. That *should* fix it.
If not, consider adding a leaf to the driver's side. However, if the springs are only two weeks old and you've fitted the springs correctly, contact the vendor and see if the problem can be resolved.
Author:  alien [ Mon Aug 01, 2016 4:16 pm ]
What Steve said. Otherwise, put a spacer under the passenger side to drop it down a bit (i'd suggest just one cut off leaf spring as a spacer, cos you're reducing clearance by doing this).
Author:  just_cruizin [ Mon Aug 01, 2016 4:32 pm ]
Spacing the diff, only seen that on old street cars - lowering blocks
You could either add an extra leaf to the D/S or remove one from the passenger side. This is really the only correct way to fix it as it varies the spring rate mm/Newton (mass X gravity)
Author:  JrZook [ Wed Aug 03, 2016 2:31 pm ]
^Agreed with JC. Adding/subtracting a leaf on the rear seems to have a much greater influence than on the front
Author:  MrRocky [ Wed Aug 03, 2016 8:01 pm ]
I run an extra leaf on the drivers side front, only way i managed to keep mine level
Author:  cairns27 [ Fri Aug 05, 2016 7:32 pm ]
The blacksmith who reset mine, made the driver's side 20mm higher... all good 5 years later...
bye
Author:  Built4thrashing [ Tue Aug 16, 2016 5:13 pm ]
I know the easy fix to this is just add a leaf to the drivers side but when i had my sierra i made the 3rd leaf in the drivers front pack a thicker leaf.(put together my own spring packs) Most sierra leaves are50mm wide and 5mm thick. I found a 7mm thick leaf and cut it to length. Fixed the lean without making the drivers side stiff..
Just another option for you.
Author:  cyprus73 [ Wed Aug 17, 2016 2:34 pm ]
Thks all.
Got the rear drivers side re curved 1 1/4inch sits a little high but should
settle down a little.
Just couldnt understand why as leafs were brand new and nothing looked
out under the car, eg diff twisted, hangers changed.
