It is currently Wed Sep 30, 2026 10:07 pm
Post Posted: Tue Aug 09, 2016 6:30 pm
Just wondering if the 2.5 gv brakes are transferable onto a sierra as an upgrade as one has lobbed in my yard.
Post Posted: Tue Aug 09, 2016 6:33 pm
They should be i think. But you will have the same issues with wheels the gv guys do
Post Posted: Tue Aug 09, 2016 6:44 pm
I run gv rims :)
Post Posted: Tue Aug 09, 2016 7:38 pm
Anything else i should pinch off the gv for the sierra
Post Posted: Tue Aug 09, 2016 8:05 pm
Rear drums/backing plate interchangeable as well i wonder ???
Vehicle: Which one?
Post Posted: Tue Aug 09, 2016 8:30 pm
Drive flanges for floaters! :-D
Post Posted: Tue Aug 09, 2016 9:00 pm
Skinny 32"s dont need no floaters
Post Posted: Wed Aug 10, 2016 5:58 am
I dont think the caliper would line up with a gv disk. U may need a sv620 disk. I know the caliper mounts are a different offset between the gv and vit
Post Posted: Wed Aug 10, 2016 6:49 pm
Gv wheel bearing hubs are the same for vitara and gv so the disks and calipers should pair the same as vitara ones do
Post Posted: Thu Aug 11, 2016 9:56 am
I don't think it will work easily. The late Vitara rotors have a shallower hat that requires a different caliper offset. (I have tried this) I guess with spacing the caliper it could work.
Post Posted: Thu Aug 11, 2016 11:09 am
is the center bore the same as sierra? I thought they were 1mm larger?
Post Posted: Thu Aug 11, 2016 2:40 pm
even if they are 1mm bigger it makes no differnce
Post Posted: Thu Aug 11, 2016 3:06 pm
So it's only an issue for wheels? I would have thought that the rotors would need to be located by the hub to guarantee they were centered?
Post Posted: Thu Aug 11, 2016 3:09 pm
wheel nuts are tapered, if they are done up they wheel is centred
Post Posted: Thu Aug 11, 2016 7:18 pm
Just mocked them up on a sierra hub
Seem to fit well but contact the dustcover in places, also discs about 5-7mm larger than the dustcover.
Prob be midweek before i try put them on my car and bleed them up
Post Posted: Fri Aug 12, 2016 8:00 am
yeah that happens on all the sierra brake up grades.
Post Posted: Fri Aug 12, 2016 8:38 pm
So calipers look to fit no dramas but the discs dont have enough backspacing by about 20mm. Will need vitara discs to make it work
Post Posted: Sat Aug 13, 2016 8:03 am
2 litre Vitara discs don't have enough offset either so your stuck at ventilated 1.6 rotors.
Post Posted: Sat Aug 13, 2016 8:12 am
They are both 46mm offset and gv is 29mm. 1.6 is only 17mm thick and gv and sv620 are 22mm thick
Users browsing this forum: No registered users and 172 guests
