| model clarification (sj50 - sj70) http://auszookers.com/forum/viewtopic.php?f=5&t=5312 |
| Author: | bron5on [ Mon Jun 22, 2009 6:57 pm ] |
| Post subject: | model clarification (sj50 - sj70) |
Hey guys, just a quick question regarding the model of my sierra. It's an 89 wt soft top, id plate states it as a d-ute 1.3 sj50. How is it that most sj50s I have seen are nt models? I heard someone mention an 89.5 (as in year of manufacture) model and wondered if that's what mine is? I guess it's a mix of sj50 and sj70 parts cobbled together as the model was changing but I could be very wrong! Any clarification would be much appreciated! Cheers! Bronson. |
| Author: | royce [ Mon Jun 22, 2009 7:09 pm ] |
| Post subject: | Re: model clarification (sj50 - sj70) |
all sj70 will be WT the 88.5 WT was called an SJ50,I dont think they ever called them an SJ70 and I dont think any sj50 WT ever had the steel flares either. you should have WT width flares but made of plastic and not steel, a WT dash and possible NT 3.9 diff centres, I think the bits that seem to move around the most are you can have either diff centre and either driveshaft, I dont think any of them had a transfer handbrake pretty sure they all had the NT version of motor and box as well. |
| Author: | bron5on [ Mon Jun 22, 2009 7:16 pm ] |
Interesting. Mine copped the steel flares (i know they're steel, had to beat them back into shape with a hammer once!) and judging by the complete lack of modification on the vehicle when we bought it back in the mid 90s, i'd say they are factory fitted. Not sure about the diff centres tho. Never had them out. Thanks for that matey! Edit: Dash is wt, 1.3 is 1324cc and no transfer handbrake. |
| Author: | shep [ Mon Jun 22, 2009 8:21 pm ] |
my 89 hard top is a sj50 and the only difference that i have found is it had the 1324cc instead of the sj70 1296cc motor. |
| Author: | lump_a_charcoal [ Mon Jun 22, 2009 9:39 pm ] |
1324 is a drover donk isn't it? |
| Author: | dank [ Mon Jun 22, 2009 10:01 pm ] |
My 88.5 was a bitsa... 3.7 diff gears, WT diffs, plastic flares, NT diff flanges !!! |
| Author: | Saam [ Mon Jun 22, 2009 10:22 pm ] |
1324 is g13a early 1.3 they changed them to 1298 for some racing class or something |
| Author: | Santos [ Tue Jun 23, 2009 2:30 am ] |
i think the g13 switched from 'A' 1324cc to 'B' 1298cc block once the gti made its debut the gti had to be under 1300cc to fit in the lower rally class and from a tooling oint of view everything followed suit ( the 'b' block has extra mounting holes for accesories and a knock sensor location) the 1324cc WT tracks where probably suzuki using up its stockpiles since by 88 'jimnys wides had be phased out domestically for the next 5 years or so |
| Author: | joeblow [ Tue Jun 23, 2009 3:45 am ] |
Santos wrote: i think the g13 switched from 'A' 1324cc to 'B' 1298cc block once the gti made its debut
the gti had to be under 1300cc to fit in the lower rally class and from a tooling oint of view everything followed suit ( the 'b' block has extra mounting holes for accesories and a knock sensor location) the 1324cc WT tracks where probably suzuki using up its stockpiles since by 88 'jimnys wides had be phased out domestically for the next 5 years or so suzuki were being taxed for producing a 1.4 litre, which is a big thing in japan, so they down sized the motor so to be taxed as a 1.3 litre. wide tracks were introduced to please the overseas market mainly, but you could buy a wt 1.3 in japan if you could justify the hefty extra cost. ( 1.3 wt's in japan were like the sahara version of landcruiser) |
| Author: | Saam [ Tue Jun 23, 2009 3:35 pm ] |
more for insurance and everything over there for a wide also someone get me some of these fancy slimline weather sheilds lol
