It is currently Sat Oct 03, 2026 5:47 pm
Post Posted: Thu Jun 25, 2009 5:41 pm
Hi All,
I've decided to make some extended shackles myself. I've already purchased the metal (40mmx6mm Flat Bar & 30mmx30mmx3mm Box Section) and bolts (1/2 Inch by 3.5 Inches Zinc Plated)
Does anyone know what length the Box Section should be ? It will be welded between the flat bar for strengh.
Any help would be much appreciated.
Cheers,
Daniel
Post Posted: Thu Jun 25, 2009 6:01 pm
As much or as little as you like.
Most people dont even run a box in the middle. But i do.
Post Posted: Thu Jun 25, 2009 6:03 pm
Same length as the crush tube in the bush??
Vehicle: '92 Sierra
Post Posted: Thu Jun 25, 2009 6:07 pm
As Scrawn said. Bolt up the stock shackle and measure the length of the bolt from the inside face of both sides of the shackle.
Post Posted: Thu Jun 25, 2009 6:09 pm
But it depends on which way he is asking length..
Post Posted: Thu Jun 25, 2009 6:37 pm
I just bought some new crush tubes recently, they are about 64mm. I'll check on the weekend the exact length.
Post Posted: Thu Jun 25, 2009 10:23 pm
I went 58mm for a snug fit so it wouldn't flog out the pin holes
Post Posted: Fri Jun 26, 2009 12:54 am
Thanks guys,
Might just go with 60mm to be on the safe side.
Cheers,
Daniel
Users browsing this forum: No registered users and 173 guests
