| 84 lwb tray back fuel tank http://auszookers.com/forum/viewtopic.php?f=5&t=53414 |
| Author: | greavesyzook [ Sun Oct 23, 2016 8:38 pm ] |
| Post subject: | 84 lwb tray back fuel tank |
iv been told that an 85 paj tank will fit is this correct?? i need a new tank in my lwb and cant find one!!! i all ready know the swb is the same but the pipes are different and no body around here will change them |
| Author: | Gwagensteve [ Sun Oct 23, 2016 8:53 pm ] |
| Post subject: | Re: 84 lwb tray back fuel tank |
Any number of tanks will fit if you move the mounts (which you'd have to do). SWB vitara goes in easy behind the rear axle. Steve. |
| Author: | sideways [ Sun Oct 23, 2016 9:26 pm ] |
Jackaroo tank fits behind the rear axle with custom mounts. 88L IIRC. Pretty sure long ranger or one of those mobs still do a bolt in long range tank. |
| Author: | greavesyzook [ Sun Oct 23, 2016 9:38 pm ] |
Yeah long ranger do but its for the swb.. I'll just have to modify one by the looks of things. |
| Author: | sideways [ Sun Oct 23, 2016 9:42 pm ] |
100% I was looking it up maybe 6 months ago and someone was selling one specifically for the midmount factory trayback tanks. |
| Author: | greavesyzook [ Sun Oct 23, 2016 9:44 pm ] |
There hard to find lol |
| Author: | jonfromhamilton [ Thu Nov 03, 2016 7:01 pm ] |
U could make an ugly one and regret ur design after all ur hard work like i did |
| Author: | claytox [ Thu Nov 03, 2016 8:01 pm ] |
For people with tanks behind the axle, wheres your spare wheel? (Lwb) |
| Author: | Gwagensteve [ Thu Nov 03, 2016 9:03 pm ] |
In the shed at home, where it belongs. |
| Author: | greavesyzook [ Fri Nov 04, 2016 7:35 am ] |
Pretty rare ya need a spare on a Zook claytox... I haven't had a flat tyre yet and Iv had zooks for 10+years |
| Author: | Gwagensteve [ Fri Nov 04, 2016 7:53 am ] |
The factory under tray spare mounts fail and the spare falls out anyway. See, even Suzuki knew you didn't need it. I joke, but I have almost 25 years of Suzuki experience. I've never seen an unrepairable tyre failure. |
| Author: | greavesyzook [ Fri Nov 04, 2016 11:14 am ] |
Still no luck with a tank |
| Author: | mrw82 [ Fri Nov 04, 2016 4:44 pm ] |
Gwagensteve wrote: The factory under tray spare mounts fail and the spare falls out anyway. See, even Suzuki knew you didn't need it. I joke, but I have almost 25 years of Suzuki experience. I've never seen an unrepairable tyre failure. I tore a valve stem off on a rock. That was pretty unrepairable trackside. |
| Author: | Gwagensteve [ Fri Nov 04, 2016 8:49 pm ] |
Not at all. Sure, it takes a little time and some tools but it's completely repairable. |
| Author: | greavesyzook [ Fri Nov 04, 2016 9:55 pm ] |
Steve is right. Unless you have a giant gapping hole in your rubber most stuff you can fix if you have the right kit |
| Author: | jdk81 [ Sat Nov 05, 2016 8:05 am ] |
The aldi $20 ki |
| Author: | mrw82 [ Sat Nov 05, 2016 10:41 am ] |
Gwagensteve wrote: Not at all. Sure, it takes a little time and some tools but it's completely repairable. Ok, so it's repairable. But it's a lot less effort to put the spare on. |
| Author: | Gwagensteve [ Sat Nov 05, 2016 11:45 am ] |
Sure, but carrying an impractically heavy and bulky spare because it's easier that repairing a valve stem or reseating a bead doesn't make sense for tiny cars that are so payload limited. Example - a full sized spare on my car would require me to carry almost nothing else in my car, and it weighs 50Kg. So I carry tyre levers, spare valve stems/cores, and plug kit. Interestingly, I've never required any of it for my own car. I did recently break off a high-flow valve stem, but as these are threaded, I removed it and threaded in a plug. I didn't need to remove the tyre (or even the wheel from the car) Steve. |
| Author: | greavesyzook [ Sun Nov 06, 2016 5:58 pm ] |
Fixed it with a heap of 50-50 solder hopefully it won't leak again!! |
