It is currently Thu Oct 01, 2026 2:35 pm
Post Posted: Sun Nov 27, 2016 1:24 pm
I've picked up this housing but am curious about a couple of the brackets that's are welded on.
Am thinking it may be a coily, brake mounting to brake mounting distance is the same as WT as is the pumpkin offset.
Post Posted: Sun Nov 27, 2016 1:26 pm
It's got NT spacing spring mounts and a shock mount welded on ready for U bolt flip
Post Posted: Sun Nov 27, 2016 3:06 pm
If you give me an overall i can measure a wt housing i have
Post Posted: Sun Nov 27, 2016 5:53 pm
Overall width is the same as WT, this was the one I was going to send you. I have had it side by side a WT housing
Post Posted: Tue Nov 29, 2016 5:13 am
Yeah i dunno then. That bracket is throwing me off. It maybe its a jimny rear end im unsure
Post Posted: Tue Nov 29, 2016 9:59 am
Jimnys are wider than WT. Coilys are shorter than Jimny yet wider than WT.
So probably not much help :lol:
Post Posted: Tue Nov 29, 2016 10:16 am
some weird Maruti WT housing?
Post Posted: Tue Nov 29, 2016 1:39 pm
Maruti identical to normal wt
Post Posted: Tue Nov 29, 2016 5:50 pm
what has brake lines coming down off both sides??
Post Posted: Wed Nov 30, 2016 8:53 pm
Late model jimny. Only thing i know of
Users browsing this forum: No registered users and 112 guests
