http://auszookers.com/forum/
Chromo circlip
http://auszookers.com/forum/viewtopic.php?f=5&t=53604
Author:  MrRocky [ Sun Dec 04, 2016 11:44 am ]
Post subject:  Chromo circlip
Anyone have a pic of the circlip on chromo axles that seats the axle in the cv. Internal circlip ?
Mine have separated and i just seem to have the remenants of what once was
Author:  just_cruizin [ Sun Dec 04, 2016 1:48 pm ]
Post subject:  Re: Chromo circlip
Common problem, get in contact with Tanshi, can may be able to provide some at a reasonable price
Author:  MrRocky [ Sun Dec 04, 2016 9:11 pm ]
Its ok bodged it up haha dont ask
Author:  J--A--C--K [ Mon Dec 05, 2016 5:12 pm ]
Tie wire for the win
Author:  MrRocky [ Mon Dec 05, 2016 6:41 pm ]
Keychain ring haha
Author:  losfer [ Mon Dec 05, 2016 7:43 pm ]
Thats actually .... pretty good.
Author:  J--A--C--K [ Mon Dec 05, 2016 8:12 pm ]
I was going to say key ring, dammit
Author:  shep [ Mon Dec 05, 2016 8:16 pm ]
Addition to the spairs kit
Duct tape
Cable ties
Fencing wire
Key ring
Nothing can't be fixed
Author:  losfer [ Mon Dec 05, 2016 8:22 pm ]
milk crates ?
Author:  Angus Martin [ Thu Dec 08, 2016 10:02 pm ]
So you just squeeze the circlip in as you put the axle into the CV yeah? My cromos just arrived today, how can you take the axle out of the cv with the circlip there, Just keep hitting it?
Author:  MrRocky [ Thu Dec 08, 2016 11:54 pm ]
You dont/shouldnt need to
Author:  tanshi [ Fri Dec 09, 2016 8:45 am ]
only reason to pull the axle is to swap it if you break an axle and need a new shaft. in that case you can get them out by destroying whats left of the shaft.
Author:  Angus Martin [ Fri Dec 09, 2016 8:14 pm ]
Yeah that's true.
Author:  Red89 [ Mon Dec 12, 2016 5:27 pm ]
Slide the axle into a piece of pipe that is big enough to fit the axle but small enough so the cv cant fit in. Bash the other end of the pipe into the ground so that the axle/cv is vertical, if you hit it hard enough the axle will pop out one end, leaving the cv behind.
Author:  Angus Martin [ Thu Jan 12, 2017 8:29 pm ]
Not a bad way to do it
