It is currently Mon Sep 28, 2026 4:29 pm
Vehicle: 1999 Grand Vitara LE
Post Posted: Tue Jan 10, 2017 12:23 pm
Hi All,
Hoping you can help solve a bit of mystery, GV 1999 LE 2.5 Auto, after some heavy rain the car (mostly) refuses to turn over, acts like a dead battery, clicking sound but no g,o had battery tested and is all good, won't start off another battery or jumper kit but will start off jumper leads if the other cars engine is running. Had some checks done with multi meter, earth is fine, asked around up here and generally people say it makes no sense, could be starter motor? Started fine this morning but then for no apparent reason won't start without jumper leads off a running engine later.
Greatly appreciate any help.
Vehicle: 2006 2.7 prestige auto.
Post Posted: Tue Jan 10, 2017 5:23 pm
When you are using jumper leads are you putting the negative connection on the engine or the battery ? I had a Magna that behaved the same the engine to engine bay earth had broken away clipped the jumper lead to th block instant start when I went the the battery similar issue.
Post Posted: Wed Jan 11, 2017 11:46 am
Hi Marck,
On the battery
Vehicle: Suzuki Grand Vitara 04 manual
Post Posted: Wed Jan 11, 2017 5:26 pm
next time it doesn't start try tapping the starter gently with a lump of wood or small hammer while someone cranks it. If it starts your starter is sticking and needs to be rebuilt/replaced/cleaned.
Vehicle: sc100 se416 mightyboy
Post Posted: Wed Jan 11, 2017 11:01 pm
Starter Motor.very common in GV's had a few do it and even got one doing the same thing at moment. I usually just replace buts that's easiest for me, reckon auto electrician would be able to fix it easy as it must be a connection fault in starter itself...
Why make your Suzuki like a Vitara, Just get one.
Post Posted: Wed Jan 11, 2017 11:28 pm
Another vote for putting the black negative jumper lead directly onto a solid chunk of engine, rather than over the top of the battery terminal.
Don't know if the rain just goes along with cold weather = a bit harder to start than when warmer - still could be starter motor, but maybe pull off the battery terminals & give them a good clean & refit, nice & tightly.
Rgs, Michael
Post Posted: Thu Jan 12, 2017 12:17 am
It's usually the brushes - as they wear down the springs loose tension, and they don't make proper contact - you do need to get it early because they will arc and destroy the commutator surface.
Post Posted: Sat Jan 14, 2017 8:44 pm
Yep, would make perfect sense, easy fix also...'if get it done early enough'
Post Posted: Tue Jan 17, 2017 2:59 pm
Thanks for all the advice, auto electrician said it was the starter motor and has replaced with new one, claimed it was cheaper than trying to fix the old one.
Users browsing this forum: No registered users and 117 guests
