It is currently Tue Oct 20, 2026 9:46 am
Post Posted: Tue Jul 16, 2013 8:43 pm
HI al,
Not sure if this is wanted but thought id put it up.
Well today i was having a few more troubles with the idle on my carbie, Its all ready had a kit put through it so pulled it off to unblock the idle jet and give it a once over. It was pretty shaged bit of throttle shaft play and heap of (AWSOME) mods by the previous 500 owners.
So a quick search on the net and found a carbie place just down the road. went down and had a extended chat with the ins and outs and a heap of different options available. I really just wanted something easy to tune was pretty much bolt on and could get me going ASAP. EFI was an option but i just didn't have the time.
Here is a link to the weber i bought. http://www.thecarbyshop.net.au/latest-news
MIchael the owner was great to deal with and very helpful he has purchased all of these webers NOS from the us, If you want more info just give him a call.
Ok so ill throw some pics up and show every one the process took about 2 hours all up.
Tools:
spanners
Hamer
Tig welder/Glue.
Grinder/dremal with cut off wheels.
scribe
ruler
Stanley knife
Got over this pretty fast
This is the kit i Picked up from the shop as it come.
first of all I took the 2 space/adaptor plates off the bottom of the carbie. and pulled them apart. they were all ready marked for me by the shop.
Next i got the original space place that sits on the inlet manifold and using a flat blade screw driver i bevelled the edges of the whole i could sit in the lead ball provided.
Using the lead ball provided i filled the hole in the original plate by simply sitting the ball in the whole and lightly tapping it with a ball pean hammer until it was nice and flat had to work it into the hole a little but with the ball but was pretty straight forward. then i cut off the excess lead with a stanley knife blade.
I then put down a gaskit then the original base plate then gaskit then the first of the 2 spacer/adaptor plates from the kit and bolted it into place.
Then i bolted on the second adaptor and locktighted it in place.
Then bolted carbie new throttle cable mount on,
I then bolted the template piece onto the original hat as seen in the first picture making sure that i marked the centre line and the position that it needed to be in so that it lines up with the original airbox. once i was happy with how it was i scribed around the template.
Then got the grinder out and started to hack away, it would be alot easier with a dremal or 2inch cut off air tool.
checking the size f the new hat adaptor, still needed to trim a bit more.
Got it to where i wanted it.
Then went into worlds smallest work shop and started to put the new adaptor ring on.
This helps..
Owner of the carbie shop doesn't weld his on and uses a compound to stick them on cant remember what it was called.
all welded on.
Then using the threaded rod supplied with the adaptor i fitted the modified hat and then cut down the threaded rod to the correct size.
Then refitted 2 the vac advance hose and the vacume hose that goes to your canister. Blocked off the old choke water hoses and the other vacuum hoses.
Fitted up fuel hose and throttle cable.
Gave it 2 pumps and turned it over started straight away and sat perfectly on idle. pompoms pompoms pompoms Armsup Armsup
So i thought id better take it out for a drive and wow what a difference midrange pull is so much more and the power improvement is great.
I have heard all the stories about webers on angles but i was assured that the DFT Weber didn't have these problems so i took it out and tried it out on some angles and inclines and could not fault it.
It was not an easy decision to go with the new option (cause im a tight arse) but im very happy that i did it.
Mods just delete this if its not wanted or in the wrong place.
Mick
Vehicle: WT sierra, GU CRD
Post Posted: Tue Jul 16, 2013 8:51 pm
Hey Michael, does it drive good?
Mark
I love ZD30. :)
Post Posted: Tue Jul 16, 2013 9:01 pm
Hey mate, yeah drives good, makes some awsome sounds too. :lol:
Post Posted: Tue Jul 16, 2013 9:33 pm
I hell of a good upgrade from that, is take it all off, and the manifold, and cut out the very restrictive two holes from the old carby, use the adaptor plate as a template.
You will feel a much improved throttle response over that with you feel with the carby upgrade.
IMO weber should put this on the installation instructions, its a must.
From memory, they are only something like 26 and 28mm for a sierra, you can port them out tow near 3 times that in total.
Nice job, what model is the carb ?
Post Posted: Tue Jul 16, 2013 9:55 pm
carbie is from a 1.6 escort. with choke removed and jets changed.
I found one on ebay after i bought mine would save some one some $$$ just buy the adaptor plate.
http://www.ebay.com.au/itm/New-81-82-Es ... 1e8&_uhb=1
From what i have been told Michael from the carbie shop darwin has bought all of the NOS stock that was in america and he adapts these carbies for everything. He had 3 others in there he was building for zooks down south when i was there today.
Post Posted: Wed Jul 17, 2013 12:52 am
Nice write up!
As SuziBlu has stated, the intake manifold really needs to be ported out to match the adapter plate. Without the porting it really messes up the flow.
That carb looks very similar to the 34/34adm weber that was used on the early falcons.
Post Posted: Wed Jul 17, 2013 4:45 pm
Ok looks like this afternoon im match porting it then.
Post Posted: Wed Jul 17, 2013 5:32 pm
Redline sell an alloy adapter that goes between the weber and the zook air hat.
No mods needed.
Post Posted: Wed Jul 17, 2013 6:20 pm
want33's yeah they sell one for the other style weber with the 4 bolts to adapt to the suzuki middle bolt air hat. this weber is bolted into the middle standard.
That adaptor wont work on this carb. :x
Vehicle: suzuki sierra
Post Posted: Wed Jul 17, 2013 6:54 pm
how much did this kit set you back?
Post Posted: Wed Jul 17, 2013 11:26 pm
think it was
550 for carb
110 for adaptor plates
and 30 for air hat adaptor ring.
worked out about the same as the ebay jobs.
But this carb works on all angles and i can call up anytime and get advice.
Post Posted: Thu Jul 18, 2013 5:57 am
Fair enough.
I didn't look too hard at the pics, just assumed it's the usual 32/36 DGAV/EV.
I had a bit of a search on Google and cannot find it.
Tried: DFAV, DFEV, DGV, DGAV DGEV, DCNF, DGMS, DCOE, DCOF, DCOA.
What is it's designation? Is it a real Weber or a Holley weber?
Post Posted: Thu Jul 18, 2013 10:32 am
Try 32/34 weber DFT Jas.
Post Posted: Thu Jul 18, 2013 3:48 pm
Close Dan but no cigar for you.
Post Posted: Thu Jul 18, 2013 6:35 pm
22/22
Post Posted: Wed Aug 07, 2013 9:36 pm
well cut out the middle of the inlet manifold and spacer plates, and also match ported the inlet manifold goes great now and is working at all angles too.. Armsup Armsup Armsup :rambo:
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Aug 07, 2013 9:39 pm
there not so bad if set up correctly :) good work
Post Posted: Wed Aug 07, 2013 9:42 pm
i reckon a 22/22 would be ideal for a 1.3 zook, the mk1 cortina GT's ran a 28/36 on a 1.5l, no pollution gear on it though.
Vehicle: SJ70 1993
Post Posted: Thu Aug 08, 2013 6:21 am
When i had mine. inside the hat was a vein that split the air into the top of the web.
made the hat cause of the body lift made the angle of a modify stock hat a pain
Post Posted: Thu Aug 08, 2013 9:17 am
How does your hat go (makntracks) iv got one for my 32/36 wich doesn't stall on hills ether just wont idel on anything more then 41deg snhles cause the floats so low
Post Posted: Thu Aug 08, 2013 10:12 am
This carb has the float bowl running down drivers side of the carb not at the rear or the front of the carb like some other Webber's, if that makes any sense. It can nearly be tiped upside down before it spills fuel or the float flips.
Vehicle: Sierra 1.3
Post Posted: Wed Feb 01, 2017 8:33 pm
Hi guys - just found this whilst trying to fix the woes with my recently purchased/installed carb from 'The Carby Shop' and all I can say is beware and spend your money elsewhere....
The theory behind the fitment is fine, but the carb which they are currently supplying is a 'no name' Weber ADF copy which is just rubbish and has been nothing but trouble which they just want to keep patching up.
I know there is nothing worse than lurkers who come on forums to denigrate stuff, but if anyone has any questions, feel free to PM me as I would rather no one else wasted $600+ with this mob!
Cheers.
Post Posted: Thu Feb 02, 2017 1:44 pm
I quite like my stock carby that has been stripped of pretty much most things that dont make it go. The car gets left during the week and only driven every second weekend or so and it starts beautifully every single time.
Sorry to hear about your experience with the carby shop :(
I love ZD30. :)
Vehicle: Sierra 1.3
Post Posted: Thu Feb 02, 2017 7:51 pm
Yep, just been one frustration after the next with a couple of minor niggles that ruin an otherwise good item. The problem was that I was fed up with the repeated offers to 'repair' a brand new carb which shouldn't need repairing!! Like you, I am going to return to the stock carb and grab an Empi replica of the original OEM item from Suzisport I think. They are more complex, but aside from the water choke, really are a great bit of kit. Just like yours, my OEM carb was really flawless, just had a stuffed choke which spoiled things a little.
Users browsing this forum: Google Adsense [Bot] and 229 guests
